Frequent Flyer
Removing tweed & spray glue from door panel
I have a set of squarebody door panels that were covered with tweed a long time ago.
I am wanting to pull off the tweed & try to restore them back to a semi-factory look. Any suggestions on something strong enough to remove the glue without damaging the plastic? Also any tips for removing the tweed? |
Tot Roddin'
Re: Removing tweed & spray glue from door panel
bump... anyone?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
you can try a heat gun some glues will release with the right amount of heat but you'll have too watch no too warp the panel.
anytime i had too remove lamination,veneers,formica or any other substrate that was spray glued(contact cement) I allways used laquer thinner or actetone and a putty knife to help to cut the gooey strings right at the separated seem. although I've never done it too a door panel so before you try it I would test a hidden spot before going full bore. also try some gasoline. I've used gas too take paint off the (abs or plastic) panels in the hatch/trunk of the pontiac and it didnt harm them at all and worked quite well it just required some serious cleaning afterwards also just be carefull with any ignition points in the area ![]() I would imagine with tweed the juice of your choice should soak right through too the glue once you try a small part
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Frequent Flyer
Thanks!
I would just like to save the GM door panels & restore them instead of buying aftermarket panels. I guess I will just have to try to get all the tweed of first then experiment with the different options of chemicals for the glue removal. |
![]() Join Date: Dec 1999
You have to redye them anyway Correct? I would put them in a blast cabinet turn the pressure way down and blast them, Wash them, wipe them down in thinner and dye them.
White gas....pick it up at walmart in the camping area....stuff you use in lanterns. Won't hurt anything and devolves glue
![]() Join Date: Dec 2013
Use regular gasoline , I have been building interiors for 35 + years and it's really the only thing that will SLOWLY eat the glue and still retain the original grain on the panel ,Now of course you want to be outside to use it and away from any ignition source but it works and won't melt the panel like lacquer thinner or acetone will . the old tweed when soaked will release from the panel and then you can start the long cleaning process using gas and a rag ,many times the panels were covered because they were already damaged by the sun and dry rotted already , take your time and it will come off .
Acetone and rubber gloves......
Ben ![]() |
When I laid carpet at Mastercraft boats we used a 3M product called Citrus Base Cleaner. We used it on everything since the glue guns sprayed all over the side of the boat and inside the plastic compartments. It was amazing and it doesn't smell bad either. I would follow with a degreaser since it is a little oily.
meowMEOWmeowMEOW
I have a clothes steamer I use to stretch and soften materials when doing tweed door panels etc. If you steam the thing first it'll loosen the folded edges and give you an easier start to "lift" the stuff from the door. Just like a sticker, getting it off in one piece makes life much easier...then you follow up by removing the glue from the door panel. Easiest way to remove glue is to know WHAT glue was used then pick the solvent; heat, acetone, alchohol, spirits/thinner.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Moderator
![]() ![]() Join Date: Aug 2011
Dry cleaning solvent.
I would think 3M release agent would do the job for the adhesive
As it releases weatherstrip cement without hurting paint. HTH, Ben ![]()
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
