01-17-2013, 12:47 AM | #1 |
The Older Generation
Need A Key For Your Suburban Tailgate Lock?
This "How To" is for the guys & gals that have a tailgate lock for their Suburban but no key. It is pretty straight forward but I have had a couple of people ask me how to get a key cut for them.. First thing you have to do is remove the latch and lock assembly from your tailgate (if it isn't already out). (picture 1) Then remove the two screws and remove the lock assembly (picture 2) and set the latch aside. Push down on the bottom spring cup and remove the snap ring. (picture 3) Then slide the spring assembly out making sure to keep the parts in order.(picture 4) If you will notice the spring cups are different on each end of the spring. After you have the spring assembly out slide the lock cylinder and shaft out. You don't have to worry too much about this as it will only go back in one way. On the cast piece just below the chrome cap you should find a code number stamped.(picture 5) A good full service locksmith should be able to cut you a key from that code number that will fit the lock. I can't guarantee there will be a code number on every lock, but if there isn't, a full service locksmith can remove the chrome cap and make a key by "reading" the wafers in the cylinder.. If you can't find anyone in your area to cut a key from the code # or by reading the wafers let me know. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-03-2016 at 11:43 PM. |
01-17-2013, 10:25 PM | #2 |
Re: Need A Key For Your Suburban Tailgate Lock?
Very nice write-up, LockDoc! One thing to mention is the rarity if some key blanks. My 67 uses the same key for all the locks and ignition. Since I only got one key with the truck, I wanted a couple spares. Nobody in town had the blanks! My key is a small GM/Briggs and Stratton with an octagon top. There were 3 or 4 different blanks commonly used back in the day, but mine was not so common. I had to order blanks from key-men.com at a cost of about $7 a blank! I got 5, and had them all cut for my Burb at a small Chevy dealership that still had an older style key cutting machine. They all came out perfect, and the guy at the parts counter didn't even charged me for cutting my keys!
01-17-2013, 11:15 PM | #3 | |
Yes, those Briggs & Stratton octagon head blanks are getting hard to find. They were only used on the '67's and some '68's. 7 bucks each is actually not a bad price. I have quite a few replacement ones but only a few of the original GM ones. There were only two different ones used on the trucks, the '67 used the "A" keyway and the '68 used the "C" keyway. You can also use the "A" keyway blanks with the larger rectangular head on them. They will work fine on your '67 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-17-2013 at 11:51 PM. |
03-19-2013, 04:51 PM | #4 |
THanks for the How too, But here is my question: How do I rekey the doors and the back hatch to the same key? The back hatch is original, and I tried to have it rekeyed to the doors and ignition set. They said it could not be done because the original hatch lock uses an odd type key configuration that's not used anymore. And they couldn't rekey the other locks to that type key? Am I making sense?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-19-2013, 09:13 PM | #5 |
My guess would be you have a lock that uses the old octagon key like I have for all the locks and ignition on my '67. Not sure if anyone makes a "newer-style" lock that fits your gate. (I'm speaking of the one that uses the oval top GM key that was used for centuries on nearly every GM car and truck!) Maybe LockDoc will chime in on this one. If anyone would know, it would be him.
Maybe swap out the whole mechanism for one from '71-'72? |
03-23-2013, 12:05 AM | #6 | |
It is really hard to say without seeing it. I keyed the locks in this set alike last year with no problems. http://67-72chevytrucks.com/vboard/s...d.php?t=557871 Can you tell me what the letter designation is on the keys for the ignition/doors and on the keys for the tailgate lock? They should be "A", "B", "C", "D", "E", "H" "J", or "K". Let me know. I'm betting I can key it like your other locks. That's the difference between a good "regular" locksmith and a "maverick" locksmith... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-23-2013 at 01:03 AM. |
08-04-2013, 11:38 PM | #7 |
Was able to purchase a Briggs & Straton NOS (dated 1974) locking unit with two keys from a member on this site. Just got it installed today and it works great.
As I am new to working on a 69 GMC Suburban rear lock setup the drawing and information were great help. Thank you for posting the pictures. I will say that it would be great if the two front door locks and the rear lock were keyed alike. Is this possible? |
08-04-2013, 11:44 PM | #8 | |
No problem on posting the info. Glad to do it. Will the key for the front door locks slide into the rear door lock? I know it won't turn it but will it go in? If so the lock can be keyed to match the front doors. LockDoc
10-19-2013, 12:20 AM | #9 |
I need help too, LockDoc. I just picked up a 72 Suburban, and the ignition and front doors are keyed the same, the key slides in the rear lock. but the button stays popped out, the PO added a hasp he riveted into the hatches. the access door is missing so I can see inside. The tailgate opens when the button is pushed but the hatch never locks. What do I need to do to make the button work again?
03-19-2013, 09:18 PM | #10 |
Maybe. My key isn't octagon top though. It's gold and square top. Looks like the other one I have, but the keyed part looks different as far as the grooves.
10-21-2013, 01:18 AM | #11 |
I oiled everything up. i didn't really understand how the mechanism is supposed to work. the tailgate closes well and locks, the hatch locks into place just fine. the button releases the hatch and then the tailgate just fine. the adjustment screw is about a 1/4 inch from touching the hatch latch, the key doesn't turn in the cylinder, it slides in but does't turn. I appreciate you helping me through this.
10-21-2013, 11:16 AM | #12 | |
It could be that the key is not going into the push button all the way. If you haven't, put the penetrating oil nozzle into the key hole and spray it. Then insert the key and remove it 3 or 4 times. The picture below shows approx. how far the key should go in. If that doesn't help you will have to remove the latch as explained above and get a key made from the code number or get the lock cylinder re-keyed to match your existing key. LockDoc
10-21-2013, 12:05 PM | #13 |
I ordered a set of locks from Leon, but haven't had a chance to put them in yet. My rear hatch does what I think you are describing. The key will go in, but will not turn. If it is already in the unlocked position, it still functions a normal, but won't lock. If it is in the locked position it will push in, but not open the hatch or gate, and will not turn. I have to put my key in and jiggle it to make it turn. Sometimes it will take a few minutes. Other times I will put it in gently, not ram it in, and wit a light touch turn it and it will turn. I'm hoping the new lock from Leon will fix it. Does that sound like what yours is doing?
Shawn
10-22-2013, 12:12 AM | #14 |
Thanks Leon, I'm thinking I will have it re-keyed to match my other set since I have a matched set for ignition, doors, and glove box. But Yeah Shawn, that sounds like my situation. it's popped out and won't lock, now I understand how the lock is supposed to work too so, Thanks Guys. I'll try your suggestions to see if that helps. does the stand off screw not touching the hatch make a difference?
10-22-2013, 11:36 AM | #15 | |
Not as far as whether the lock turns or not. If the hatch and gate open OK I would not mess with it... LockDoc
03-17-2014, 09:35 PM | #16 |
Leon,
I got the locks installed in the burb this weekend. It's great to have all of them work with the same key - including the lift gate. Thanks again for offering this service. For anyone out there thinking about getting all your locks matched up, I recommend Leon's service. Fast, and super reasonable prices. Regards, Bill
Bill 1972 GMC Suburban 3/4 Ton 1970 C30 Holmes 440 |
03-18-2014, 11:08 AM | #17 | |
Thanks Bill. I appreciate that. LockDoc
04-09-2014, 11:00 PM | #18 |
I need the lock tail shaft for a 71 suburban tail gate. Mine no longer engages the plate it contacts. Have'nt found one anywhere.
04-14-2014, 10:19 PM | #19 | |
Welcome to the board. Sorry about the delay in responding to your question. I'm not sure I understand your problem though. Is your tail shaft broken? It only contacts/engages the plate when it is in the unlocked position.In the locked position the tabs on the tail shaft just push through the plate.... LockDoc
04-15-2014, 02:06 PM | #20 | |
04-16-2014, 12:23 AM | #21 | ||
LockDoc
05-15-2014, 07:23 PM | #22 |
When I can, I will remove the assembly, photo it and try to explain my issue better. May be a while?
Allen |
04-15-2014, 09:53 AM | #23 |
I am sure this is a stupid question, but will a suburban tailgate fit, and lock on a pickup? That would be so neat! Thom
