01-21-2013, 10:14 PM | #1 |
78GMC Project for Life
I'm pretty new here, but i've been doing my homework over the last year and decided on this 78 gmc shortwide as a project. Now from the crazy rides you all have done, which all are in a league of the own i decided on a Mcgaughys 4.5/6 for mine, which consisted of 2 1/2 spindles and 2inch springs and flip kit and cnotch out back with belltech drop shocks all around. Now i have the front finished and have moved to the rear. My only issue back here so far is that PO removed some leafs or maybe not. I dont know. I have 2 long leafs and then a short one on the bottom. I ve been looking like crazy. I understand that there was a 52 inch and a 56 but my question is how many leafs should i use on mine? Any help would be appreciated and pictures will be coming shortly. Thanks for any help.
01-21-2013, 10:50 PM | #2 |
Re: 78GMC Project for Life
Welcome to the boards! I'm in okc not too far from you. My truck had 6 leafs and the overload after flip, Im running '67-'72 trailing arm now.
Rally 'round the family....with a pocket full of shells. |
01-22-2013, 09:40 AM | #3 |
My 84 has 3 and the overload which resulted in about a 5" drop..If you have only 2 you won't get a 6" drop out of your flip kit.
01-22-2013, 11:34 AM | #4 |
Since your in the city. If you need a set of leaf springs I will give you mine just pm me and come get them ASAP
Posted via Mobile Device Posted via Mobile Device |
01-22-2013, 01:39 PM | #5 |
Hell yeah. Thanks for the responses.
So if I'm understanding right here I need more leafs For more drop. Man that sounds stupid when I say it. That makes sense. So I ll probably go with 3 and the Overload. What size are those leafs that you don't need? I ll take em. I'm gonna measure mine and see and let u know. And how many leafs are there. Thanks again guys. Posted via Mobile Device |
01-22-2013, 05:24 PM | #6 |
Hey rich can u elaborate a little. Am I looking for more leafs for more drop. Is that how it's working?
01-22-2013, 10:19 PM | #7 |
No thats not how it works. If your truck had all the leafs in place before you installed the flip kit you would net a bigger drop. Adding leafs will slightly lift the truck with the flip kit installed or not.
John 82 Chevy Silverado 350ci/TH350 |
01-22-2013, 09:10 PM | #8 |
No you don't need more springs unless you dont like the ride.
Do the flip you will be happy.. Posted via Mobile Device |
01-22-2013, 10:29 PM | #9 |
Ok this is what ive got. I found that mine are 56 inches and 2 1/2 wide. thats 26 center to front eye and 30 center to rear eye. With the responses and research it looks like mine is 56 which are only sold now with like 8 plus leafs. Thats fine but with what ive heard most are running like 4 or 3/1, which is 3 on top one on bottom. Well the 56 does not have that low of an option in leafs so now my brain is exploding.
01-22-2013, 10:41 PM | #10 | |
01-23-2013, 08:25 AM | #11 |
Aren't those shackles riveted in place?
01-23-2013, 05:11 PM | #12 | |
01-23-2013, 08:37 AM | #13 |
Does anybody think the leafs that I have would be ok. Or should I replace.
01-23-2013, 04:49 PM | #14 |
If you are sitting too low after you install the flip kit you will need to add leafs or replace.
01-23-2013, 05:06 PM | #15 |
When I first did the flip it kinda freaked me out how low it was..So give it a chance. Now I look at it and think "maybe a little lower".
