08-06-2013, 03:53 PM | #1 |
2010 Camaro Wheels on Lowered C10
08-06-2013, 03:56 PM | #2 |
Re: 2010 Camaro Wheels on Lowered C10
They have a different bolt pattern...did you use the adapter?
Posted via Mobile Device |
08-06-2013, 04:13 PM | #3 |
yea, 2 inch thick, 5x5 to 5x4.75
03-27-2017, 02:54 PM | #4 |
03-27-2017, 04:58 PM | #5 | |
http://www.ebay.com/itm/4-Wheel-Adap...item4b0abc6dea Just a testament to their durability, I lost control on the 1-2 shift about a week ago and slammed my truck into a curb sideways....Broke chunks out of both of the camaro wheels on passenger side and tore holes in the tires and these spacer adapters held up. that was alot of force exerted and not so much as a crack or loose wheel stud. Im impressed.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303 My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw |
03-27-2017, 05:05 PM | #6 | |
03-27-2017, 08:41 PM | #7 |
03-07-2020, 12:32 PM | #8 |
Active Member
What's the best way to make this work swapping over from a 6 lug setup?
I've got some 5gh Gen Z28 wheels I want to run and don't an to toss the Baer brake system I'm running. If I can simply swap to a 5 lug rotor and run a spacer, I'd be all over it. |
08-06-2013, 04:20 PM | #9 |
I like it
08-06-2013, 04:36 PM | #10 |
They are ok, seen worse looking wheels for sure.
1985 C10 2004 Avalanche |
08-06-2013, 05:03 PM | #11 |
looks good, gives it a street truck look. What did you have on there before?
08-06-2013, 05:11 PM | #12 |
08-06-2013, 05:44 PM | #13 |
Thumbs up from me. I saw them on another truck and the did not look so good. Maybe it is cause your truck is lower.
Experience is something you gain when you didn't get what you wanted in the first place. No great defeat was ever just possible in the beginning. |
08-06-2013, 05:54 PM | #14 |
Slots go on anything!
They look better than I would have expected.
1974 Jimmy- 5.3/4L80e/NP241 |
08-06-2013, 06:06 PM | #15 |
08-06-2013, 07:08 PM | #16 |
They look way better than the 90s 5 stars you had on it previously... it just slightly updates the look of the truck without looking too radical... my .02
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
08-06-2013, 07:43 PM | #17 |
they are not my favorite ever but I do like them, its different. and I like that they fill the wheel wells in size and width. and I agree that I like them a million times better than the old wheels
08-06-2013, 07:51 PM | #18 |
I like 'em, gives it a modern look...it's not so 1990's anymore....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
08-07-2013, 12:57 AM | #19 |
I like it.... looks good!
08-07-2013, 01:00 AM | #20 |
Enthusiast
if 1 or 2 inches of overall diameter were taken off the rims and replaced with sidewall, i think it would be smokin
- Cole 1979 Chevy C30 w/ carb 454. 1992 Chevy K1500 w/ tbi 350. *Sold* 1997 Dodge Ram 1500 w/ Magnum 360 *Sold* "Good judgment comes from experience. Experience comes from poor judgment." - George Washington |
08-07-2013, 01:07 AM | #21 |
150 thousand times better than the b4 set.......
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
08-07-2013, 01:23 AM | #22 |
i'm with you school boy, the camaro rims are nice, but i dig the 5 stars better(but flip the white lettering out of site). has a no nonsense look to it (camaro rims make it look an oversized hot wheel)
dont always need to be updated or new to run with the crowds- old skool is cool skool |
08-07-2013, 01:40 PM | #23 |
thanks guys for the honest opinions. idk, I just cringe every time I go into the garage. I do have a friend that may buy them or trade a set of 17 inch torque thrust off his 95. if I sell them, I think a satin aluminum 15x8's will find their way on it. maybe a set of outlaw II's. I guess im just a 90's guy. btw, the other wheels came on the truck.
08-07-2013, 01:48 PM | #24 |
Frequent Flyer
Nice improvement over the old 5 stars! Keep 'em!
08-07-2013, 04:48 PM | #25 |
I know the pieces fit
I like them OK but they make the truck look taller. If you could lower it more and tuck some rim it would look better. Or go back to 15's. Rally's maybe?
