02-14-2014, 06:54 PM | #1 |
Junior Member
1971 C50 Swap Project
This is what I started with. A 71 C50, with a 350, 4speed and 2 speed rear end.
02-14-2014, 07:06 PM | #2 |
Junior Member
Re: 1971 C50 Swap Project
After owning it a while I wanted to makes some improvements and take care of some problems.
Things to fix/improve: Leaking brake cylinders Leaking master cylinder Widowmaker split rims 20 tires with tubes Smelly gas tank behind seat Rearend with very low gears Bad clutch No power steering Last edited by Flat 67; 02-14-2014 at 07:27 PM. |
02-14-2014, 07:25 PM | #3 |
Junior Member
Then I came across this donor truck for a fair price. A 1988 GMC 7000
With the following: 8.2 Turbo Detroit Diesel (not a desirable motor, oh well) 10 speed Eaton Fuller Transmission 4.88 rear end 22.5 steel wheels Tubeless tires Air brakes Power steering 2 50 gal fuel tanks So.....The swap began!!! Last edited by Flat 67; 02-14-2014 at 07:48 PM. |
02-14-2014, 09:07 PM | #4 |
Does the '88 7000 actually have a Fuller 10-Speed Road Ranger Trans? If it does, I've never seen one in a Medium Duty truck of that type.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
02-14-2014, 09:51 PM | #5 | |
Junior Member
Yes it does, when I first saw it didn't think it could be so. Last edited by Flat 67; 02-14-2014 at 10:15 PM. |
02-14-2014, 10:19 PM | #6 |
My brother n law has a truck just like the one you are starting with that he hauls hay with on the farm ,same color even .Im in for this one .
02-14-2014, 10:20 PM | #7 |
Pretty interesting. Cool Truck really. Air Brakes and all.
02-14-2014, 10:43 PM | #8 |
Junior Member
The teardown begins.........
02-15-2014, 12:12 AM | #9 |
This is going to be a cool truck.
02-15-2014, 04:27 AM | #10 |
Collector of Projects
what truck? I thought this was about a girl....
02-15-2014, 09:27 AM | #11 |
She can ride along too.
02-20-2014, 06:02 PM | #12 |
Junior Member
Pics of it coming together.
02-20-2014, 06:04 PM | #13 |
Junior Member
Front wheels stick out until I make the 8 inch cut to the front axle.
Flat67 |
02-20-2014, 07:58 PM | #14 |
Before you cut the Front Axle, you may want to consider going with the Wide Fenders, found on some C-60's with the Heavy Front Axle. They should interchange with no problem. You would also need the Wider Running Boards as well.
I'm really not a fan of converstions, but that Front Axle looks pretty cool under there. I also like the idea of a 10-Speed RR Trans in C-50. Bill
02-20-2014, 11:10 PM | #15 |
Retro look with the later model running gear with great components, possibly except for the engine............... But they're stingy on fuel. The transmission is worth as much as the engine, maybe more !
Did you have to cut the firewall to clear the turbo and exhaust pipe / |
02-20-2014, 11:32 PM | #16 |
Couldn't you use a C70 type fender? Would it be bolt on??
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
02-20-2014, 11:50 PM | #17 |
They are the ones I am referring to. The hardest part would be to find a nice set.
02-21-2014, 12:10 AM | #18 |
Junior Member
02-21-2014, 12:20 AM | #19 |
Junior Member
More pics......I got it running.
02-21-2014, 06:04 PM | #20 |
Junior Member
Motor is snug, but fits in there.
02-21-2014, 12:03 AM | #21 |
Junior Member
Bill, like you said, the wide fenders are very rare and they would probably be all rusted. Those sample pics are a great examples though. Also, I like my original paint too much and I don't want to alter that.
02-20-2014, 11:57 PM | #22 |
Here is a good example of the Fenders.
Last set of pictures, post #356: http://67-72chevytrucks.com/vboard/s...306565&page=15 Bill
02-21-2014, 09:12 PM | #23 |
That was quick ,I like it .
02-21-2014, 11:46 PM | #24 |
That 88 GMC 7000 looks just like my 79 but mine had 453T jake brake and 5 and 2. I really miss that truck.
02-22-2014, 03:08 PM | #25 |
Junior Member
