09-27-2010, 08:02 PM | #1 |
Collector of Projects
New to me 1972 K5
Ok. I'm officially back in the game. Had a rusted out 70 K5 back on the east coast. Sold that.... wanted another and finally got a nice rust free Blzer today... Needs some love but a good solid foundation. First thing is a new steering box as this thing wanders and needs constant correction... then a set of body bushings as the rubber is toast.... I think I'm gonna throw on a ORD 1" body lift too... I only have one pic so far... more to come...
Has a 4" lift with rancho shocks. A bolt in roll cage.(cant open the glove box) Double wall top (with a wavy roof). 350\TH350\NP205 combo. 33" BFGs on 80's rally wheels. Has a second fuel tank over the wheel well. Front seats have a plaid cloth cover. Might be from a newer truck. Rear bench has the scrolling and the door panesl are the deluxe ones. Last edited by mcmlxix; 07-07-2012 at 02:42 AM. Reason: fixed link to pic |
09-27-2010, 09:17 PM | #2 |
Re: New to me 1972 K5
Looks good. I like the tire/rim combo. How are you gonna do it? Back to stock or updated? I'm looking forward to seeing more pics.
09-27-2010, 10:26 PM | #3 |
looks good I see it has tow hooks.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
09-29-2010, 03:04 PM | #5 |
Very nice
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985 "The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945 |
10-01-2010, 03:09 AM | #6 |
So here are the plans so far: (after the general maintenace to make sure its road worthy)
I want to build a frame work that replaces the factory console and run a floor shifter. B&M 81040. I will try and figure out a cable operated NP205 stick to match. The original bucket seats are gone so I will probably find some late model seats that fit. There is a cage in there now but I dont like the design so that will be redone. Replace to stock bumpers with .... something. (no winch) 8 lug upgrade Front and Rear (keep stock housings) Rear disc brakes @ 8 lug upgrade time H2 Hummer 17" wheels The BIG wish list item will be an aluminum 6.0L with 4L60e/NP205 drivetrain.... Similar console idea (but in a square body) B&M H2 wheels painted D44 8 lug upgrade: http://coloradok5.com/8lugconversion.shtml Last edited by mcmlxix; 10-01-2010 at 04:47 AM. |
10-30-2010, 05:40 AM | #8 |
got the new Red Head steering box installed... its variable ratio with 3 1/2 turns lock to lock. Replaced the PS pump and both lines at the same time.... I also rebuilt the rag joint...
Now I'm fighting with the body bolts welded to the floor pan... Last edited by mcmlxix; 10-30-2010 at 05:41 AM. |
10-30-2010, 10:55 PM | #9 |
please let me know how you like the box. I am also wandering down the road
72 Blazer 4wd 72 Blazer 2wd 69 Blazer 4wd easy to take apart hard to finish. Ray of all trades master of none. |
10-30-2010, 11:49 PM | #10 |
Where did you buy the parts, and $, thanks, mine needs that
10-31-2010, 06:03 AM | #11 |
The box came directly from Red Head. The power steering pump and hoses came from the local parts store. The poly body mounts came from Off Road Design as well as the 1" aluminum body pucks... I havent driven the truck with the new steering box, I just got the body mounts in place tonight. I may need some shimms and hope to drive it tomorrow....
I ended up drilling all the heads off the body bolts. The bolts from ORD were and inch longer to make up for the added puck. They were grade 5 but have a standard hex head. I went to go get new carriage bolts but they were only grade 2 to I used the ones they sent. I'll keep looking for some stronger carriage bolts or maybe some button head allen bolts.... All the bolts came out fairly clean except the two in the passenger and driver foot wells. They are recessed and you cant get a cut off wheel in there. I didnt have a die grinder so I drilled them out and ended up ripping the sheet metal where they were wleded. In its place I used to GM late model subframe washers.... and since everyone love pics..... Old Vs. New In place Old bolt with weld still attatched along with some of my floor pan.... The washer I was talking about... fits in the recess perfectly Last edited by mcmlxix; 10-31-2010 at 06:07 AM. |
10-31-2010, 06:55 AM | #12 |
Your new Blazer looks good! Congrats. I have the same 6 point rollbar in mine - I like the back section but don't like the front.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
10-31-2010, 08:03 AM | #13 | |
Cheap to replace and you'll want fresh ones anyway, whether you replace the steering box or not. -G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
10-31-2010, 05:19 PM | #14 |
Thats funny because I think the fronts ok but dont like the back.... but I cant opent the glove box door....
11-27-2010, 07:06 AM | #15 |
Well I have driven the truck a couple times and some of that was on winding roads... It feels great but still doesnt want to come back to center... it wants to stay in the direction you last pointed it at... I think drak link ends are next...
I love the 3.25 turns lock to lock.... I also found some inexpensive 17" wheels I like.... They come in silver, black with silver lip and all black.... I want to run 35's. Anyone know the best offset/backspace? I dont want the wheels to look too tucked in.... Option A. 17x9 @ 0 offset @ 5" BS Option B. 17x9 @ -12mm offset @ 4.5" BS Last edited by mcmlxix; 11-27-2010 at 07:07 AM. |
12-09-2010, 04:36 AM | #16 |
OK... so i picked up some rear seats last month... then picked up front seats the other day....
Back seat sitting in the truck ... Front seats waiting in the garage.... |
12-09-2010, 10:51 AM | #17 |
Very nice. I want to get the same set from a Tahoe put in mine.
12-09-2010, 12:14 PM | #18 |
Future TOTM Winner
Did I read this right, you are going to convert your existing rear 12 bolt to 8 lug?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 12-09-2010 at 12:14 PM. |
12-09-2010, 12:53 PM | #19 | |
Born Psycho
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
12-09-2010, 06:44 PM | #20 |
That was an original thought but not worth the effort if its even possible...
02-05-2011, 05:32 AM | #21 |
Well its been a while since I updated....
I sold my 06 Tacoma and have been driving the Blazer daily to work. It sucks on gas but oh well, it's fun. All I did was change the fluids.... the engine leaks from the front, back and valve covers... the trans takes forever to get in gear... the original posi and carrier are junk. (no maintenance and lots of abuse) I have since sold the heated leather seats because they were from an 2003 or newer truck and the wiring was going to be a hassle. I picked up some grey cloth seats and I'll probably put in some aftermarket seat heaters next fall.... I only ever got half the black paint off... the acetone was killing my hands... The crap mirrors that were on the truck vibrate so bad I can barely see whats behind me. I won't turn in front of anyone but talk about double vision. I test fit a mirror from a Hummer H3. I'll ned to come up with somethign to fill the gap between the door and the bas of the mirror.... here are some pics... Last edited by mcmlxix; 02-05-2011 at 05:51 AM. Reason: added pic |
02-05-2011, 05:58 AM | #22 |
I have been collecting parts to get rid of the 4" lift blocks in the rear. I was originally going with the ORD shackle flip but ended up with DIY4x because it uses shackles like the ones found on the front springs... I also got a set of perches, shot mounts and U bolts from Ruff Stuff....
Today before work I went and picked up another rear axle. This one is from a 2004 Duramax SRW truck. It a AAM 14bolt full floater that has an 11.5" ring gear, 1410 yoke and disk brakes with the integral parking brake. This thing is friggin' HUGE! |
02-05-2011, 06:02 AM | #23 |
I also installed all my Moog parts... Tie rod ends and drag links... I had to recenter the pitman arm as well. the truck was still wandering. I also had to re torque the steering box bolts as the were loose and causing deflection and bump steer... It's 10x better. Now I just need to recent the steering wheel, but I think I will get an alighment first.
02-11-2011, 09:34 AM | #25 |
VA72C10
nice score on the wheels and nice blazer! Looks much better ochre
Looking for a 67-72 swb or blazer project in or around VA. |
Thread Tools | |
Display Modes | |
