A/C Compressor
It's getting a little toasty in New England and I need to get my a/c working.
Wondering if anyone has mated a stock Dodge a/c compressor with the stock GM system. I have both a 1 st gen and 2nd gen Dodge a/c compressor to work with. The 1 st gen has screw on fittings on back of the compressor and the 2nd gen has a block that bolts on. Thanks for any info
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
Re: A/C Compressor
I did find this... guess I need to find out which one I need
http://www.sunairusa.com/news/2011SandenHeads.pdf
Re: A/C Compressor
Re: A/C Compressor
6>8 Plugless........
![]() Join Date: Sep 2007
Re: A/C Compressor
I have a 1st gen comp on my Longhorn but haven't gotten around to finishing the ac system. I really need to though.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Re: A/C Compressor
Here is some info that might help...
Pic below is a 2nd gen compressor.. ![]() Pic of the lines off my 84 K20... ![]() Hoping a couple of o-rings and I can bolt the GM manifold to the back of the Sanden compressor.
Re: A/C Compressor
I have A/C on my chummins. Granted, mine is a 97, but the same idea applies.
I used the stock Dodge hose set up from the back of the compressor. Then I took it to an A/C shop and they modified the connection to fit up with the GM condesor and dryer. |
Re: A/C Compressor
I'm running a 94 dodge compressor, with some fittings I got out of a parts book at orieillys. two separate hoses with a center piece that bolts them to the compressor and they are individually clockable. then custom crimped on hoses. works beautiful.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#9 | |
Re: A/C Compressor
I'd love to get it hooked without having to weld any aluminum.
Re: A/C Compressor
I will have to see if I can dig some up. its been done for 6 or 7 years. not sure if I still have any numbers.
