Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-24-2014, 06:20 AM   #1
WEBBY1
WEBBY1's Avatar
question about swapping rear ends
I have 65 burb.. full air ride. I found a 70 rear axle. im running wires with adapters.. question is... I have a feeling the tire will hit the body line when aired out. Has anyone had any problems?
WEBBY1 is offline   Reply With Quote
Old 10-24-2014, 10:23 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: question about swapping rear ends
'70 and earlier rear axles are the same width. '71 and later are 1.5" wider. If you clear with the stock '65 axle, the '70 should fit the same.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
