07-07-2015, 12:51 AM | #1 |
Front sway bar is in...wow
Wow is all I can say. The truck feels totally different in terms of body roll and handling. Everything feels much tighter and together. Found a bar at a wrecker and ordered the hardware from Early Classics. Took me about 1.5 hours to install on my own and that included smoothing out a divot on the frame with the torch. Very easy and very worthwhile mod.
07-07-2015, 06:47 AM | #2 |
Re: Front sway bar is in...wow
yup a front bar makes a huge difference, a rear bar makes a big difference as well... not as much as the front but still worth it in my opinion.
07-07-2015, 07:49 AM | #3 |
I ordered a rear bar for my 67 thinking it would help with handling ,,, went to check the fronts bushings and surprise no bar,,, all trucks nowadays have them , and most have a rear also , surprised me to say the least .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
07-07-2015, 08:15 AM | #4 |
CAN'T FIX NOTHIN
I put the large front sway bar and also the rear sway bar fromm cpp on my 67 when I lowered it , made a big difference it will go around a curve like its on rails !
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
07-07-2015, 10:27 AM | #5 |
Does the rear bar have to be aftermarket or can it be found off another model year like the front?
07-07-2015, 12:06 PM | #6 |
subbed
Figure out what you want--then figure out what you are willing to give up to get it. |
07-07-2015, 12:31 PM | #7 |
I know guys have adapted rear sway bars from Z28's or TA's. I used the setup from No Limit. I'm still miles from driving this thing but I really like how it fits!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
07-07-2015, 01:01 PM | #8 |
The sway bar is the most easily identified modification in terms of feel.
If you do a search for rear sway bars, you will see a few different bars used from various manufacturers, and how they are mounted. The rear is probably the most flexible as far as fitment, because you can go over or under, in front or behind the trailing arms ( not sure about leafs). The suspension design offers a lot of flexibility. |
07-07-2015, 06:09 PM | #9 | |
Posted via Mobile Device |
07-07-2015, 01:00 PM | #10 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-07-2015, 01:22 PM | #11 |
CAN'T FIX NOTHIN
Id say you could use one of a newer truck and get it to fit for the rear , I got mine in with a bunch more stuff so I dont remember how much it was ,,,,,,,
07-07-2015, 04:53 PM | #12 |
I plan to put one on the front of mine I plan to keep the stock ride height and have read on here that the rear didn't make that much of a difference as far as handling but made it too stiff on bumps now im not sure?
07-09-2015, 01:58 PM | #13 |
GM did an incredible job on the suspension of these trucks, which started over 50 years ago in '63. I can't tell you how many people have ridden with me that have never ridden in an "old truck" before (or ridden in others that were really crappy... *cough* ford *cough* ) and are shocked at how well it rides/handles. I have an ECE 1-1/4" bar on my truck and nothing else, she rides and handles well for a big ole girl.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-09-2015, 02:46 PM | #14 |
Junior Member
My 72 Burb that is lowered with a front sway bar will go thru a corner much faster than our 03 Yukon.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 07-09-2015 at 02:47 PM. Reason: spelling |
07-10-2015, 12:55 PM | #15 |
Since my new (to me) 72 GMC Sierra Grande C15 rides like a boat, I guess I'll be doing this! A work friend said it made a night and day difference in his '67 C10.
Is there a list anywhere of sway bars from which make / model / year cars would fit? |
07-10-2015, 12:59 PM | #16 |
Yes there is a great write up here. Very straightforward to do.
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338 |
07-10-2015, 04:04 PM | #17 |
Yup, 1-1/4" bar is an easy snag at the bone yard.
07-10-2015, 04:52 PM | #18 |
just be carefull what you pull outa the jy.
i found this rear bar on a 2wd leaf spring square body blazer i layed in the mud too get it out on a rainy day i cant for the life of me get it too fit my trailing arm suspention without shock relocation and flex brake line relocation even then it comes to close for comfort too the springs. dummy me. but i do think its a helwig bar from the 80's at least from the searches i've done it matches one of them. of course it needs some work but the bar is soild. i allready put a 1 1/4" bar up front from a "p" van/box truck. the frame brackets i got from the p seem too be shorter and beefier than the frame brackets we got off a 3/4 ton 67-72 for the kids thinner front sway bar.I did have compairson pics but cant find'em when the times come too drive my project i'll get a z 28 rear bar just too try it out.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
07-10-2015, 04:28 PM | #19 |
Thanks!
