Old 03-05-2016, 01:01 PM   #1
Coursey
Coursey's Avatar
Need help identifying steering box
Had an issue pop up when i backed it out the steering box started leaking around the end.
I am unsure if this is a 1966 or 1985 box?
It is on a 1966 Suburban
The front rack is off of a 1985 c10, so i am unsure about the steering box.
It has 85 stamped into the end. Not sure if this means 1985 or something else.
Coursey is offline   Reply With Quote
Old 03-11-2016, 04:00 PM   #2
Coursey
Coursey's Avatar
Re: Need help identifying steering box
I figured out it is defiantly from the 80's.
Is the small gap in the seal supposed to be there?
Old 03-11-2016, 04:07 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
That's not a seal, that's a snap ring and yes it should be there.
As for the year, the boxes look the same between the Inverted Flare style and the Metric style (which uses o-rings). Easiest way I know of is looking at the line fitting. Pinch the return line close to the hardline on the box and unscrew the hardline. If it has an o-ring, it's the later Metric style. If none, then its an Inverted Flare style.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-11-2016, 04:41 PM   #4
Coursey
Coursey's Avatar
Thanks,
It is leaking out of the gap in the snap ring.
