03-30-2016, 10:24 PM | #1 |
Speaker location options - '54
What options are there for speaker locations on a '54 chevy pickup? I'd like to put two 6x9's in the cab but not sure where. Under the seat seems like it will muffle the sound too much. I still have the tank behind the seat so it seems a little limited there.
Any ideas> |
03-30-2016, 10:31 PM | #2 |
Re: Speaker location options - '54
If you get a quality set of 6.5 inch speakers and amp them, the kick panels is a great spot if you aim them up toward you a bit. You wouldn't really need rear speakers either.
03-31-2016, 01:36 AM | #3 |
There is plenty of room for a 6x9 in each rear corner of the cab My first step father kept his stash or Rainer beer in cab corner on his 54. You could build some boxes to fit each side and then put another speaker in the stock speaker location and done.
Side note I've got small boxes with six inch speakers on each kick panel of my 48. They are too handy as a foot rest though.
03-31-2016, 03:57 PM | #4 |
Check out this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=645857 I bought a set from him and the look & work great!
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
03-31-2016, 04:11 PM | #5 |
I installed the retro sound panels a few weeks ago. They sound nice even when being placed in the kick panel area. Your legs don't block the sounds and i even installed tweets just above the main speaker. The panels only needed 3/4" removed from the bottom to get them to just fit perfect. I will take a few better pics later today and post them up. I could not install the rear corner speakers as noted in the above post as the seat belt mechanism is located at the cab floor where they go. Already have the sub behind the seat and might one day install some more speakers behind the seat facing directly upward for a more immersive sound.
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! |
03-31-2016, 05:30 PM | #6 |
I have two 6 x 9's behind the seat and a 8" sub under the seat in a custom box. I have two 5" speakers in the stock location in the dash.
03-22-2021, 08:40 PM | #7 |
Where did you get the brackets for the speakers behind the grill. Do you like it up there or do you think the ones behind the seat would be enough?
My build a 49 5 window ls1 4l60e on a TCI chassis http://67-72chevytrucks.com/vboard/s...d.php?t=754926 My travel blog The Wong Winding Road-Adventures of The Chinese Cowboy https://thewongwindingroad.blogspot.com/ |
03-31-2016, 07:55 PM | #8 | |
03-31-2016, 08:26 PM | #9 | |
Motorcycle when he has revving the throttle you would hear Rainer, Rainer, and then when he took off and shifted you would hear Raineeeer... Beeeer!!!! Funny Commercial back in the Day! Allen |
03-22-2021, 11:44 PM | #10 |
I hung 2 small speakers behind seat below rear windows. I made some L brackets to do it, Running wires was a bit Had i time i would have investigated using small bluetooth speakers.
03-23-2021, 11:41 PM | #11 |
The classic car stereos have so many options!!! Its crazy. I did put 2 Polk audio 6x9s in today. we tried under the seat and it sounded pretty good but couldnt hear it over freeway speeds. so we moved it to behind the seats right below the corner windows and could hear it better. Instead of vertical were going to do horizontal and at about 25 degree angle. Still will prob put a speaker in the stock location as well.
04-08-2021, 10:38 AM | #12 |
The hertz sound great!!
04-08-2021, 10:39 AM | #13 |
Pictures would help
04-08-2021, 10:48 AM | #14 |
I bent some sheet metal as I did not want to weld it to the outer cab wall.
also welded a piece of metal to dash for a pair of 3.5 inch speakers
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 Last edited by Tempest67; 04-08-2021 at 10:59 AM. |
04-14-2021, 09:08 AM | #15 |
Nicely done Tempest
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
Tags |
1954, speakers, stereo |
