06-12-2016, 06:58 AM | #1 |
Flaring stainless tubing
I am trying to flare some stainless tubing for my Brake lines and fuel lines.the brake lines are OK but the bigger 3/8" is to hard to flare,I am using .032 wall.If I cant get this done I may have to use mild steel tube
06-12-2016, 08:06 AM | #2 |
Re: Flaring stainless tubing
Stainless is tougher to bend and form. Here's a pro level tool that I use...
http://www.mastercool.com/product/71475/ It's probably not worth the cost for a single job but it is a great tool. It also makes bubble flares, GM fuel injection flares, and some quick connect flares! I bought mine maybe 10 years ago and I couldn't tell you how many times I've used it. I also have some nice bending tools: https://www.ridgid.com/us/en/600-ser...rument-benders Again, not cheap. Last edited by 1project2many; 06-12-2016 at 08:12 AM. |
06-12-2016, 10:18 AM | #3 |
I have the same Mastercool kit and it works really well. While a bit pricey, it sure eliminated the frustration of trying to do the work with poor quality tools. I've also seen an Eastwood flaring tool in some of the posts here and members are stating they have good results.
Some guys have painted their steel fuel / brake lines after they had them formed up and fitting. Depending on the look you are going for, maybe that would be an option for you? |
06-12-2016, 11:10 AM | #4 |
A friend loaned me that same Mastercool tool for my son's Falcon brake lines and I can't scream from the roof tops enough how great that tool is!
I had did flare and reverse flare tubing with cheaper (though quality) tools before, I gave up, never to do it again. I would buy pre-made tubing and that was it, if the length wasn't perfect I would make it out of a few, or put a little bend here and there to shorten it, that sort of thing. There was just no way I was going to make them, it was a joke......that was until my friend loaned me that tool! Heck, the last two lines on the car, I just picked up a 3ft long piece, didn't matter what fittings were on it, wham bam I just made two new ones out of it using the fittings from some other lines, BAM, done. The very last one I made my son make it. He is 19 and had never touched something like this. He made an absolute perfect line from scratch. I can not say it enough, this tool makes it so damn easy it's crazy and if there is any chance you will ever make lines again, just buy the tool! It works for fuel lines too, it's a very very valuable tool to have. It makes it so easy to make lines it's just crazy! Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
06-12-2016, 11:49 AM | #5 | |
Posted via Mobile Device |
06-12-2016, 02:10 PM | #6 |
You don't say if you are trying to single flare or double flare. Generally speaking, stainless line should be a single 37 degree flare for use with AN style fittings. Stainless usually splits when you try 45 degree double flares.
06-12-2016, 02:26 PM | #7 | |
06-13-2016, 07:03 PM | #8 | |
I've never had an issue with leaks using AN and 3/8" line fittings. IMO, it's the way to go. |
06-12-2016, 02:33 PM | #9 |
Hollister Road Co.
06-12-2016, 03:11 PM | #10 |
I have the Eastwood Pro Brake tubing flaring tool and it works great on steel tubing but I haven't had cause to use it on stainless.
This tech tip from Jegs brings up one thing that is a necessity to get good flares every time and that is chamfering the ends of the tube in an out and using a saw or tubing cutter and NOT using a cut off disk. Chop saws or cut off disks heat and harden the metal where you cut it and it is hard to work or machine it afterwards. http://www.jegs.com/tech-articles/flare-tech.html
06-12-2016, 06:17 PM | #11 |
I've not used a mastercool but have the eastwood..a buddy of mine has one and it works great..
06-12-2016, 06:39 PM | #12 | |
Brian
06-13-2016, 05:08 PM | #13 | |
06-13-2016, 05:49 PM | #14 |
Hollister Road Co.
