01-08-2018, 09:25 PM | #1 |
How to connect fill tube to tank with bed on?
While I was installing the tank I thought about how I was going to connect the filler tube to the tank with the bed on, but I thought it would easily come to mind when I had the bed sitting on the frame, but now that it's on there, I'm wonder how the hell I can do it. The solutions I'm thinking of involve leaving out some screws and having to leave out some bolts that hold the bed on there. I did a couple search's but didn't see a solution to my problem. I would appreciate any help here. I kinda feel like an idiot asking these questions, but a simple solution completely evades me!
01-08-2018, 10:16 PM | #2 | |
Re: How to connect fill tube to tank with bed on?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
01-08-2018, 11:13 PM | #3 |
How do you put the hose clamp on there? Also, how do you undo the screws that secure the wood down? The nuts that are on the under side of the wood that are blocked by the fuel tank?
01-10-2018, 08:36 PM | #4 |
Still curious about how you installed he hose clamp after you put the filler neck on there and, how you got the board off there when the nuts that secure the bolts on are covered by the tank? Did you leave those bolts without nuts??
01-11-2018, 10:20 AM | #5 |
I put both hose clamps on the filler neck loose then put my piece of hose on and tightened the bottom clamp. Then put my filler top in the hose and slid the other hose clamp up and tightened it.
01-11-2018, 07:18 PM | #6 |
What I'm talking about is how you were able to get your hand in there to do that. From what I'm seeing with my truck is that, there's not enough room to get a hand in there with the bed on.
01-11-2018, 10:42 PM | #7 |
I was able to go over my frame. Like I said I have a metal bed floor, might be more room. If I remember I'll take a picture of it tomorrow.
01-13-2018, 09:45 AM | #8 |
I have a space between the bed and the top of the tank and it's about 4in. Everything is accessible from under the truck. The tank is bolted on the bottom frame rail so it can easily be taken off when I need to. I do not have to remove the bed to drop the tank.
01-14-2018, 02:44 PM | #9 |
Here is a shot of the fill tube and a shot from the bottom of the bed side looking up at the space between the frame rail and the bottom of the bed.
01-14-2018, 03:33 PM | #10 |
Seems like it would be doable with the hose clamps orientated so a socket and long extension could tighten them. That's how I've done it on 47-54 trucks.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
01-15-2018, 11:17 PM | #11 |
01-09-2018, 08:34 AM | #12 |
I think your tank is coming down again. maybe after removing the board you use a piece of plexiglass to mark the hole?
Even though mine had the hoses coming off the side the tank still went up and down a few times until it all got figured out. Disregard, I don't know either how you would do it. Last edited by vince1; 01-09-2018 at 08:42 AM. |
01-09-2018, 08:39 AM | #13 |
I have a metal floor and was able to reach my arm up in there and tighten the hose clamp. I don't know where my floor sits in relation to a stock wood floor though.
01-09-2018, 05:19 PM | #14 |
I put a mettle lockable door in the bed wood and my tank has a it's own cap. I have also seen people put a hing on one of the boards so it flips up.
01-09-2018, 08:16 PM | #15 |
I have the lmc 15 gallon tank I just installed last week and i was able to get a socket with a long extension on the hose clamps and tighten them down. This is with the factory wood bed floor
