02-23-2018, 08:20 PM | #1 |
Spindle sitting at a angle. Porterbuilt
Why are my spindles sitting at this angle? Do I have the uppers on backwards? Or am I missing something else? New porterbuilt upper and lower control arms. And new spindles. Thanks
85 Chevy C-10 383 stroker |
02-25-2018, 05:25 PM | #2 |
A guy with a truck
Re: Spindle sitting at a angle. Porterbuilt
What’s the angle? Hard to tell from pics
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-25-2018, 05:42 PM | #3 |
Sorry I just noticed the first picture was sideways.
02-25-2018, 06:22 PM | #4 |
Looks like the lowers are the 1" forward and the uppers are standard.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-25-2018, 06:30 PM | #5 |
That’s what I thought too. I contacted PBFAB tech support through e-mail and they claimed it’s suppose to sit like that. Now the front end is jacked up in the picture so it is a little deceiving but still didn’t think it would sit at a angle at all.
02-25-2018, 09:04 PM | #6 |
A guy with a truck
That’s not necessarily a bad thing. More caster (to a point) will help driveability.
02-25-2018, 09:08 PM | #7 |
True. I figure I’m over thinking things to much. It’s put together and plan on getting it to the alignment shop in the next couple of days so we’ll see.
02-25-2018, 09:26 PM | #8 |
A guy with a truck
It will also help visually center the wheel in the arch, which the stock geometry usually pushes back as you go lower. I think you’ll be happy once it’s aligned
02-26-2018, 10:56 AM | #9 | |
67-72 parts collector,…
Take it to the alignment shop and see where you’re at. Shoot for 5 degrees positive caster and you will be amazed how good it drives.
02-26-2018, 07:36 AM | #10 |
You can see from the lower ball joint angle some thing is amiss. 5 degrees of caster put the upper ball joint about 3/4" behind the lower. You can take a quick measurement and see about what you have. The picture is not shot to show the angle well if you look at the frame. I would set the truck level on stands and take another look at what you have.
Jimmy
03-01-2018, 11:16 AM | #11 |
This isn't exactly a level picture either, but it's a lot closer to level than your photo. I have Porterbuilt 1" forward lower control arms and stock uppers with CPP modular spindles. There's definitely an angle to the spindle. You'll want to verify that it's not as drastic as the photo looks, but there will definitely be some angle.
Oh, and a piece of advice. Ditch the lock washer and standard nut on the shock mount (shock side) and get a locking nut. I've had both come off after several miles of driving (different times), even with a dab of blue lock tight. Either that, or put a lot of the blue lock tight on that bolt.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-01-2018, 09:56 PM | #12 |
[QUOTE=knomadd;8200520]This isn't exactly a level picture either, but it's a lot closer to level than your photo. I have Porterbuilt 1" forward lower control arms and stock uppers with CPP modular spindles. There's definitely an angle to the spindle. You'll want to verify that it's not as drastic as the photo looks, but there will definitely be some angle.
Oh, and a piece of advice. Ditch the lock washer and standard nut on the shock mount (shock side) and get a locking nut. I've had both come off after several miles of driving (different times), even with a dab of blue lock tight. Either that, or put a lot of the blue lock tight on that bolt Thanks for the advice. I’ve got it all put back together and out of the alignment shop today. It drives good, but now I’m trying to figure out how to keep the inside of my rims from grinding on the lower control arms when I make sharp turns. Did you have any issues with this? I know the control arms are filthy but it rained here all day.
03-02-2018, 09:13 AM | #13 |
You can do some grinding on the lower control arm at the place it is rubbing on the wheel. Has to be done on stock control arms with drop spindles and 15 inch wheels with 4" of back spacing. I have had to do it on my last two trucks. A bigger diameter wheel or less backspacing clears just fine.
Jimmy
03-02-2018, 10:05 AM | #14 |
Thanks. I’m going to mock up some spacers to see if that’ll help. I plan on getting new rims with in the year just don’t really want to send the money right now.
03-02-2018, 03:23 PM | #15 |
I didn't have that problem because I had 22x9.5's when I did the swap, now I have 19x8s and both cleared just fine. It looks like your wheels are a bit too small for that amount of low. Are you running 15's?
DO NOT, I repeat, DO NOT grind the ball joint cup on the Porterbuilt control arms. They are part of the structure of the arm and you'll weaken it, or at the least start to mess with the ball joint to control arm cup spacing, allowing dirt and moisture in from the bottom. It's fine on a stock arm because that lip isn't part of the ball joint structure. There's a limit to how much you can do to a stock arm before it becomes weak, which most guys who grind them don't go that far, so it works.
03-02-2018, 03:28 PM | #16 |
17” eagle alloys. Thanks for the advice.
03-10-2018, 12:49 PM | #17 |
I just went through the same thing. Caster looked way off so I took it to get aligned, and cast was 14 degrees. Called up PB and they made me take measurements of the upper control arms. They sent me the stock uppers and 1" forward lowers. They did replace the uppers free of charge, but man what a kick in the pants. Had to take them all back apart, and repaint the new ones. I have not been really happy with PB stuff.
The thing I didn't get was that I thought the 1" forward lowers were supposed to work with factory uppers. We could not get caster any lower then 13.0. Have not had it realigned yet but it does look a lot better.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax Last edited by 68is4me; 03-10-2018 at 12:58 PM. |
03-10-2018, 02:30 PM | #18 |
That’s exactly what’s happened to me. Same degrees on the cast and all. I talked to Nate on Monday and he is going to send me the right ones. I agree it has been a huge pain but at least PB is trying to make it right I guess.
03-13-2018, 01:05 PM | #19 |
Maybe we got a bad batch. When did you get yours? I think mine came in midsummer of 17. I never really did ask if they sent stock uppers, maybe they were complexly wrong in the 1st place.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
03-12-2018, 10:43 AM | #20 | |
The narrowed arms won't work with factory uppers.
08-02-2018, 11:00 PM | #21 |
That's funny but not funny. I think I have the exact same rims as you too. 17 boss and mine also rub. I was going to try a 1/2 spacer but I am sure that I will have to change studs. For now I am just driving it and being careful when turning.
08-03-2018, 05:48 AM | #22 |
Ha. Yea I went with a 3/8” spacer. Seems to work fine. I did have to change studs though.
08-10-2018, 01:42 PM | #23 |
Mine are also 3/8. I did find a good trick tho instead of replacing studs I found these lug nuts for crager rims. Not sure your lug nut size but mine 1/2-20. And these fit the Boss rims perfectly and give you extra thread.
