Old 03-18-2018, 08:58 AM   #1
blazer2007
fr. air bag,need a spacer ?
I need to put a 1 inch spacer in the front air bags on a 78 , do I have to separate the lower ball joint or can I squeeze it in.
blazer2007 is offline   Reply With Quote
Old 03-19-2018, 01:30 AM   #2
bbbc10
Diggin The SquareLife
Re: fr. air bag,need a spacer ?
spacer for what reason
bbbc10 is offline   Reply With Quote
Old 03-19-2018, 12:39 PM   #3
tinydb84
tinydb84's Avatar
If you let your suspension hang and disconnect your fittings you should be able to muscle it in.
David
Instagram: myfabguy
Old 03-19-2018, 07:02 PM   #4
blazer2007
thanks, I had a 2 inch spacer but was too much and took it out but now I need 110 lbs. for ride height so I will cut it in half and try that. No compressor hooked up and last year I tried to release the ball joint it didn,t want to with out some pressure pushing on it. Plus I hate wrecking dust boots. Waiting for spring, long winter this year
