04-12-2018, 03:58 PM | #1 |
Changing from a Low Hump to a High Hump
We searched for tips and how to's on removing a low hump trans tunnel and installing a high hump. Not much out there. So, I decided to document how we went about the task of making room for a TH400 in a '68 C10.
NOTE: We did not have access to a lift, plasma cutters or metal shears. If you have access to those tools or if the transmission is out of your truck you could vary how you remove the low hump. First step... we picked up a new repro high hump from Chuck Hutchinson at Truck Haven in Unionville, TN. Chuck is a great guy and has anything you might need for a C10.
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
04-12-2018, 04:03 PM | #2 |
Re: Changing from a Low Hump to a High Hump
After removing the brand new low hump carpet that we had just installed, we placed the new high hump in positon over the low hump and temporarily installed Dorman bolts in the two existing holes in the floor pan. Using a permanent marker, we marked the location of the eight remaining holes. We then removed the high hump, center punched the hole locations and drilled them to size.
04-12-2018, 04:09 PM | #3 |
The existing floor pan has an continuous indention that can be followed when cutting. If the truck doesn’t have a transmission installed you can remove the old hump with a metal cutting wheel, plasma cutter, metal shears or pneumatic cutting saw.
Be sure to wear safety goggles and gloves for the next steps. Since our truck had the transmission installed we used an Ingersol Rand pneumatic air saw with a medium tooth metal cutting blade. Be very careful while cutting to make sure that electrical wiring, modulator valve line, transmission dipstick tube and transmission cooling lines are clear of the blade. Be careful lifting the cut out metal section because of sharp edges.
04-12-2018, 04:18 PM | #4 |
We trimmed the metal opening near the hole locations and installed Dorman fender clips.
This evening we are going to transfer the hole locations for the Lokar shifter to the new high hump and re-install the shifter hardware. Stay tuned... more to come! POP
06-04-2020, 04:06 PM | #5 |
Are these fender clips 1/4"? If not, what size did you use?
06-04-2020, 04:25 PM | #6 |
Just here to tinker
Nice work!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
04-12-2018, 06:37 PM | #7 |
Can’t wait to see!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
04-12-2018, 08:57 PM | #8 |
67-72 parts collector,…
What was the reason for going to a high hump?.
04-13-2018, 10:56 AM | #9 | |
POP
04-13-2018, 01:02 PM | #10 |
Thanks for the reply.
04-13-2018, 11:05 AM | #11 |
After applying a bead of Urethane Adhesive around the perimeter we finished installing the High Hump in the truck. Now the transmission has plenty of room. Not sure how others were able to use a Low Hump with TH400 and not experience clearance issues. In our case the High Hump is the only way to go.
We are going to apply more ThermoTec Heat/Sound Deadener to the panel and then new High Hump Carpet. POP
04-13-2018, 11:29 AM | #12 |
Nice work guys, thanks for the post!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
04-13-2018, 11:31 AM | #13 |
Looks great! I bought a new high hump to convert to a Lokar. Can you tell
Me roughly the placement measurements you made for your shifter mounting location?
04-13-2018, 01:22 PM | #14 |
WOW...that looks nice!
What is the cost of a repop high hump?
Jimmy Hoelzel |
04-13-2018, 01:53 PM | #15 |
Mine was from Cooper Restorations - $95 before
Shipping.
04-13-2018, 03:37 PM | #16 | ||
04-14-2018, 12:33 AM | #17 |
Mine is labeled Key Parts underneath
04-15-2018, 05:43 AM | #18 |
Scrapper 1
I was wondering if they made that part cool
04-15-2018, 02:43 PM | #19 |
yes i got mine fom summitracing. just cut the floor to fit it
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
06-04-2020, 05:17 PM | #20 |
My understanding trucks with t400 came factory with high hump
I did this on my 68 gmc when i went from 2x4 to 4x4 there is a spot welded ring that is below the floor pan for use of bolts not sheetmetal screws to secure high hump pan |
02-18-2021, 01:15 AM | #21 |
...Yes TH400 trucks had high hump . I got a used cover from a donor truck 'cause my '67 C10 already had the floor cut and a truck 4 spd with a butchered high hump . I cut a fresh hole for a car 4 spd shifter and I'm still using it today(24 yrs later.) Now it has an TH400 shifter mounted in the same hole.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
02-19-2021, 11:38 PM | #22 | |
08-02-2022, 07:31 PM | #23 |
Maybe this is getting a little off track but since you brought it up I will report that my 1970 GMC2500 3/4 came stock with the TH400 and a low hump. I had to double check since I recently purchased carpet and had to get the hump right
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
02-17-2021, 10:59 PM | #24 |
Senoir Member
Thanks for posting, nice work. That color looks familiar too....or close to my 70 GMC
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
02-19-2021, 10:21 PM | #25 |
i see a lot of posts where people say they have this problem . i wonder if i dont because i used aftermarket engine and trans mounts . it is really tight with the t400 but its almost a half inch . i have horsed it enough to snap the carrier bearing off the mount but never herd the trans rub or hit . i wonder if theres a way we could measure the height of the motor and trans using the factory mounts vs the aftermarket tubular ones
