07-16-2018, 11:41 AM | #1 |
Any idea what motor this is?
Bought this 64 c10 recently and I am looking to do a tune up, however I haven't been able to verify that this is the original motor or something put in later. I have been looking for markings on the motor but there is potentially 50 years of grime on it and it is a slow process, additionally searching google for chevy motors hasn't turned up anything that looks exactly like this... Anyone have any idea if it is a 283 or ???
looking to change the oil/filter/drain plug, plugs/wires, new air filter, battery, etc... just looking to make sure I buy the right stuff the first time!!! New to Chevy and new to the forum excuse my inexperience!! thank you in advance!!
1964 C10 |
07-16-2018, 12:03 PM | #2 |
Re: Any idea what motor this is?
post a shot of the end of one of the heads.
07-16-2018, 12:13 PM | #3 |
Moderator
Air cleaner and orange block say 70s 305, 307, 350. What side dipstick?
07-16-2018, 01:10 PM | #4 | |
Right side dipstick
1964 C10 |
07-16-2018, 02:36 PM | #5 |
1962 C-10
Definitely late 60s-70s sbc of some sort.
I see a points style distributor, accessory holes on the heads... probably 307 or 350. A safe bet to say to the guy at the parts counter, 1970 c10. As for the air filter, take it in and have it matched up.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 Last edited by jchav62; 07-16-2018 at 02:42 PM. |
07-16-2018, 03:41 PM | #6 |
Moderator
I'm diggin the transcooler.
07-16-2018, 11:18 PM | #7 |
Thats actually a left hand dipstick engine. it has a spin on filter so most likely a 1968 or later. also has a long water pump, 1969 and later pass car or 1973 and later truck. Are the spark plugs 5/8 " or 13/16" early engines had 13/16" plugs. The stamped ID number is on the block pad under the alternator . The cast block number is on the drivers side of the block below the back of the drivers side head near where the trans bolts on.
07-17-2018, 12:18 AM | #8 |
60-66 Nut
What Lumpy63 said /\ /\
My guess would be a '73+ truck engine either a 305, 307, 350 or a 400. I see what looks like maybe the counterweight on the flexplate? I also see what looks like the impression of the middle freeze plug like some of the later 400's have instead of the actual freeze plug. That would make it a 400. The suffix code on the pad below the alternator will tell you exactly what it is.
07-17-2018, 04:15 PM | #9 |
Moderator
Post those babies up.
07-17-2018, 06:04 PM | #10 |
Captain Fab nailed it! I can see the center freeze plug boss and if you look real close you can see the scalloped balancer. So yes it looks like a 2 bolt main 400 .Just so happens to be one of my favorite small blocks most likely 73-74 vintage.
08-01-2018, 01:59 PM | #11 |
After a bit of procrastination due to the heat... I took the time to take the alternator off today and found this.... after a brief search online it appears to be a 1976-1977 or 1979 400 out of a k20, 2500 or a "van"
thanks for all the help
1964 C10 Last edited by LBNY_C10; 08-01-2018 at 02:09 PM. |
07-17-2018, 01:05 PM | #12 |
If it's a 400, and you bore it out, pay the extra to have it bored and honed with a torque plate.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
07-17-2018, 02:38 PM | #13 |
Moderator
Damn, I totally forgot the 400! Nice call.
07-17-2018, 02:44 PM | #14 |
I appreciate the input everyone!!! Will post up when I solve the mystery!!
1964 C10 |
07-17-2018, 03:51 PM | #15 |
I bet its a 400, 2 bolt main.
