07-29-2018, 10:20 AM | #1 |
Removed fuel tank have some rust what would you do
As I mentioned we were excited to get power in cab fuel tank removed but underneath I definitely have some light to moderate rusting issues with some pitting. The truck is already been painted so not sure sandblasting is an option. I've read about different rust treatment things such as POR 15 and Eastman products just curious if any of you have opinions or thoughts? I've also read about some gels and products tht are supposed to help dissolve the rust. Or do I attack it with some sort of sanding/grinding blade. Oh and light rust under the old headliner too
07-29-2018, 12:06 PM | #2 |
Re: Removed fuel tank have some rust what would you do
I'm thinking wire cup brush and rust converter. Not a big fan of doing it that way but it may be your best option.
You could mask it off and sand blast it without too many problems with a small sandblaster. My little Sears blaster doesn't cover a lot of area at one time. Messy inside a cab though.
07-29-2018, 12:16 PM | #3 | |
Also do you have any experience with any specific rust converters? |
07-29-2018, 12:26 PM | #4 |
Mr48chevy
Something like this? Or what do you have if you don't mind me asking https://m.sears.com/search=craftsman...r%20kit%20with |
07-30-2018, 11:01 AM | #5 |
https://www.harborfreight.com/21-oz-...gun-95793.html
Harbor Freight makes this little gun. I have a friend who uses his regularly. But with that paint in there (and blasting inside a cab is awful...you'll find sand for years) I would definitely just use POR on the inside of the cab. Probably the same on that other part. Do as much mechanical removal as you can without damaging paint. Then POR over what's left. |
07-30-2018, 12:24 PM | #6 | |
07-30-2018, 02:17 PM | #7 | |
07-30-2018, 02:32 PM | #8 |
Get some Rustoleum Rusty Metal Primer. Blow away the loose stuff & spray it with that. I have used it for years. It seals the rust & leaves a tough coating. You can paint it the next day.
07-30-2018, 04:55 PM | #9 | |
And thanks mr48 Chevy I'll checkout the cup brush and start there. I'll definitely look into the 2 suggested sandblaster sounds useful but maybe not in the cab like b-mac said but hey I live in the country so good luck she will always be dusty haha Thanks again |
07-31-2018, 07:29 PM | #10 |
use a rust converter like rust Mort and then paint . Paint is the only way to stop rust look up miracle paint, better than Por
http://www.tptools.com/Bill-Hirsch-M...aint,2553.html |
08-15-2018, 02:40 PM | #11 |
so attacking my rust today. Have a wire cup brush which I feel kinda smooths but more so polishes my rust haha. bought a different disk and it's doing better I think as I'm finding some shiny metal but I have a bit of pitting in the floor pans area. guy had it hidden pretty well under spray Bedliner 😣
Any suggestions of tools that might be better? or is this ok? Also those that suggested sandblasting. trying to research mediums to use. any recommendations for what medium might be best in your experience? going to do wheel well area which is just needing light cleaning and then the floor pans and area from fuel tank that has heavier duty rust I was planning a path of rust stop products but thought the more I can remove 1st the better especially the scaly stuff. you can see I am finding some raw metal but have along ways to go. |
08-16-2018, 10:07 AM | #12 |
I think you're on the right track. Those black fiber disc things you are using work pretty well.
I also have pretty good luck with these things: https://www.harborfreight.com/catalo...2Cf&q=abrasive But I use an old, crappy, plug-in drill. Good for inner corners and such. I was in the exact same spot as you, and I decided to blast the inside of my cab. I live in a fancy-smanchy neighborhood, so I did it inside my garage, inside a tent basically. It was freaking awful, and probably took years off my life. If I could go back, I would not have done it. Either send the whole thing out to have a professional blast it, or clean what you can, convert it or POR whatever, and get to driving it faster. Whatever you do, the truck will probably outlive you... That said, I use coal slag for blasting. Good for rust, cheap, and won't give you lung cancer. Sand works much better, but do a little research on silica, and you'll change your mind. Any of the other media probably won't touch your rust. |
07-30-2018, 04:25 PM | #13 |
That was basically what I was suggesting with taking a cup brush on an angle grinder to it and putting the rust converter on it. Several ways do do it and help it last for a long time to come.
