10-10-2018, 11:54 PM | #1 |
76 Chevy C10 Hydraulic Clutch Conversation
Hello everyone
I have a 76' Chevy C10 with an automatic transmission that I would like to convert to manual I already have an engine I'm pulling out of my older 71 Chevy that has a hydraulic throwout bearing setup and a Muncie M21 4 speed that I would like to keep, I really liked the set up. Has anyone converted over using a hydraulic throwout bearing instead of the factory 85 and newer hydraulic setup? |
10-11-2018, 08:04 AM | #2 |
Re: 76 Chevy C10 Hydraulic Clutch Conversation
I did not use the 85+ stuff because people want an insane amount for the pedal set. I mounted a wilwood master on the firewall and bolted it to a manual linkage pedal. There are pics and details in the NV3500 swap link in my signature.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
10-11-2018, 09:12 AM | #3 |
I got my clutch master and mounting kit from American Powertrain (their HydraMax line). Has an adjustable mounting bracket for the master. Works gret on my T56. I used mechanical clutch pedals (84 and older). You can see the master bracket in the pic.
10-12-2018, 12:39 AM | #4 |
That's exactly what I needed thank you very much for the pictures I have that exact wilwood clutch master so that will be perfect
10-12-2018, 06:18 PM | #5 |
driving is in my blood
Why not use the oem manual clutch setup? Its easy to push and gives great feedback unlike most hydraulics.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
10-12-2018, 08:46 PM | #6 |
Only reason being is because the engine and transmission I have is already together with the right amount of shim for the hydraulic throwout bearing I'm using and I can't see a way I could use the factory setup with my hydraulic throwout bearing without separating the transmission, buying a new manual throwout bearing, new bellhousing and clutch fork and all the rest of the parts I would require
10-13-2018, 04:48 PM | #7 |
That's a pretty good reason lol
