Old 08-07-2016, 02:50 PM   #1
bluex
bluex's Avatar
NV3500 Install in a 78 C10
This is how I went about installing a 96/97 S10 NV3500 into my C10, this way worked for me and will probably be a little different if you use an older or newer transmission. I would stick with 96 and up though as they are the strongest versions of them.
Parts list:
Purchased through Rock Auto
Flywheel: LUK LFW101 – 78 C10 5.7
Clutch Kit: LUK 04160 – 98 C1500 5.0
Hydraulic bearing assembly: LUK LSC265 – 98 C1500 5.0
Purchased through Speedway Motors
Rod end-5/16: 1170720
Master Cylinder: Wilwood 70174-750
Banjo bolt kit: 5151398
36” stainless line -3AN: 91031846-3
Adapter-T56 release bearing: 5151396
Remote Bleeder kit-12”: 5151399-12
Ok so to start I put in the clutch pedal box and pedals. I didn’t take many pictures of this, it took a while and you’ll have to remove a good portion of the interior. It helped to loosen the seat and slide it to the passenger side so you can lower the steering column as well. Yes I did use a much cheaper Z-bar (manual linkage) pedal assembly. I cleaned it up, put in new bushings and pedal pads while I was at it.
bluex is offline   Reply With Quote
Old 08-07-2016, 02:53 PM   #2
bluex
bluex's Avatar
Re: NV3500 Install in a 78 C10
Master cylinder mounting
To mount the master I used the hole that speedometer cable passes through the firewall. If you’re using a 96 and up trans the cable is now useless anyway since those trans have a VSS and no provision for a mechanical cable. I plan to us a GPS speedometer app on my phone for now. This is about as high as you can mount it without getting into the area in the cowl for the wiper linkage. It could go up another ¼” maybe but I don’t think that’s necessary and it would be pretty close to the wiper motor then.
I made a template of the back of the master cylinder and lined it up using the existing hole as the lower left side of the mounting hole. I traced out the metal that needed to be removed and cut it out using a dremel tool with a cut off wheel. I attempted to use a hole saw but with no pilot hole it was too hard to control so I just followed my scribed line with the dremel and worked it down until it cut through. I know it looks close and it is but it doesn’t touch the brake booster or the wiper motor and you can easily remove the cap to add fluid.
I then made a plate out of some aluminum I had laying around to help spread out the load on the firewall. I threaded the holes in this plate so that the bolts act more like studs and you don’t necessarily need two people to take the master on and off. To attach the master to the clutch pedal I had to make some modifications to the pedal itself and make an extension to the master cylinder rod. The extension is just a piece of round stock that I drilled and tapped to 5/16-24 on both ends. I took a bolt and cut the head off to attach the extension to the rod end. Now the rod reaches the pedal, but it wants to land in the exact spot the old pedal return spring used to hook to. So I removed the pedal and cut that off flush with the edge of the pedal arm. After another test fit leaving the rest of that pad resulted in the master cylinder push rod being on an angle. This master can take a slight angle but too much will result in premature wear/failure. You also need to make sure the rod is close to level up and down for the same reason. So I cut part of that pad off to give clearance to the rod end. I used two washers to space it out a little and a nylock nut to ensure it stays connected. *in the pictures are 3 washers, I later removed one to lessen the angle on the push rod
I was worried about having a high pedal effort with it mounted about 3.5" down from the pedal pivot point. It was nothing to worry about now as it is no harder to use than a factory manual linkage setup, or anything with a high performance clutch. I’ve driven many other vehicles with a pedal that is much stiffer than this one wound up being. That could be partly from my clutch selection but it turned out good so I’m happy with it.
Old 08-07-2016, 02:55 PM   #3
bluex
bluex's Avatar
Hydraulic hookup
During my research I found that the NV3500 uses the same hydraulic bearing assembly as a T56. This helpled me out as I could follow the path that many had used to swap a T56 into older vehicles. This is also why I used the wilwood master since I found much more info about using it in swaps than trying to cobble together two different factory setups (C10 hydro master to newer internal slave).
So on the bearing the factory quick release fitting is held in with a roll pin. Drive that pin out and the factory connection will pull loose from the assembly. You can then install the -3AN adapter the same way, just push it in until it’s seated and reinstall the pin. The pin was a tighter fit with the adapter than the factory one was. The banjo bolt kit is used to convert the master cylinder over to -3AN and simply fits in the end of the master, one sealing washer on each side. The 36” line I used was the perfect length for my truck, if you want to route it differently you’d need a longer one though. The remote bleeder was also nice to have but isn’t necessary. It did make bleeding the clutch much easier and was well worth the extra money to me. The 12” length is enough to reach it easily while under the truck and tie it up to the frame out of the way when you’re done.
Old 08-07-2016, 02:57 PM   #4
bluex
bluex's Avatar
Shifter
I found out the hard way here that S10’s and a C/K 1500 don’t use the same shifter. The shifter I got with my trans was a mess. Parts were missing and it was rusty from being left outside. After a lot of searching I found a used one from a 1500. The problem was that they used a different size thread for the shifter handle and the pivot point was higher up on the shifter itself so I couldn’t bolt the shifter to the trans. After some more research I found that Lokar makes a replacement shifter rod for these transmissions (part # MSL610). It shows two locations for the pivot pin and shows in the instructions how to disassemble the stock shifter and what holes to use when replacing the arm. With this info I took my C1500 shifter apart, lowered the pivot ball down and redrilled the hole for the pivot pin. It now works perfect and it fit the shifter arm I had got years ago from a full size truck. I liked it because it was longer and it lands in the perfect spot to reach from the driver’s seat. The S10 shifter arms are much shorter and wouldn’t have been as comfortable to drive with.
To cut the hole in the floor I had the engine and trans in place and measured off one of the factory stamping ribs in the floor to the center of the shifter. I drilled a hole there and double checked that it was in a good location. After that I marked out the cut and I purposely made it smaller than I needed. Once I saw how that went I cut it to size so I was able to remove and install the shifter from inside the truck.
Note—In 98 or 99 the S10 shifter moved farther back on the trans which is similar to all C1500 shifter locations (I believe, they could have changed in the same year range). If you use a newer trans than I did your hole will be located farther back towards the seat.
Old 08-07-2016, 02:58 PM   #5
bluex
bluex's Avatar
Trans Cross member and Driveshaft
The transmission cross member did have to be moved back from the factory location. If you are converting from a TH350 it will be quite a ways back from where it was. I converted from a 700R4 and still had to move it back some. I used the same mount on the NV3500 that was on my 700R4 and that mount came off my TH350 when I did that swap.
My driveshaft fit right back in like it did with the 700R4. If you are converting from a TH350 you will have to have the shaft shortened. Check with your preferred driveline shop on how they would like you to measure for the correct driveshaft length.
Old 08-07-2016, 03:00 PM   #6
bluex
bluex's Avatar
Clutch Selection
This is where I hit a brick wall. I had read several places that you could use a factory clutch setup for the vehicle the trans was going in with this swap. Well that was bad info for me and my parts setup which caused me a lot more work than necessary. Hopefully I can spare someone else that trouble.
The NV3500 has been around since the late 80s in the GMT400 platform (88-98 trucks). It is called by several different names over that model year run but the early ones used and external slave cylinder that pushed on a clutch fork much like the mechanical linkage setup that would have been factory on a C10. I can only guess that on that style trans you could use a clutch setup for a C10 and it would work perfectly fine. In my case with the internal hydraulic bearing it didn’t work. I had a slightly used 10.5” clutch setup that I had gotten from a friend. It came with everything clutch related that I needed including a 153 tooth flywheel that I bought a brand new starter for. Well I noticed that when I put the trans on the engine it kept springing back when I pushed it up on the dowels and I had to draw it in the last little bit with the bellhousing bolts. I thought that was odd but I also don’t know a ton about clutch setups so I thought it might just be normal because of the pressure plate. Well it wasn’t and once I got the rest of the truck together it wouldn’t move because the clutch was never engaging. It wouldn’t even engage enough to make a burning clutch disc smell. That’s when I found out I needed to use a clutch for late 90s C1500 for proper operation. I don’t think you can use a S10 clutch as they might use a smaller 11” flywheel but I’m not 100% sure on that. In order to avoid buying the wrong parts again I just used a C1500 clutch as the flywheel sizes looked to be the same between it and the one for my C10. The difference in the pressure plate heights was right at a ½” and explains why it would never engage. Once I looked at the pictures of the two pressure plates I could tell the difference and knew I had found my issue.
Old 08-08-2016, 06:18 AM   #7
74CustomK20
74CustomK20's Avatar
Good info and will be tuning in when I finish mine up. Only difference is mine is 4x4.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 08-08-2016, 11:29 AM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
On the flywheel... I have a generic 1st gen crate 350. When I looked up flywheels for a 1972 350 the LUK one didn't come up (I think they make good stuff, I'd like to use that one.) Will it work on the older 350's? GM didn't go to a one piece rear main until like 1985?
Where did you get the bolts for the pressure plate?
Also, can I use my 700R starter, or do I need a different one, and what would I "get one" for?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-08-2016, 12:26 PM   #9
bluex
bluex's Avatar
As far as I know you should be ok with the flywheel I listed as that that is a mulit year replacement engine. I see the LUK one isnt listed under a 72 but the others listed under a 72 are also listed under a 78 so I think you would be ok to use the same one I did.
The pressure plate bolts I had with the clutch setup I tried to use originally, I just used them again. You could pick up a set at oriellys, one of the greenville stores was the only one that had them local, on Laurens RD I think.
http://www.oreillyauto.com/site/c/de...re+plate+bolts
The starter needs to be a stagered bolt pattern 168 tooth to fit the flywheel. As long as you have a 168 tooth flexplate (which you probably do) then the starter you have should work just fine. Alternatively if you wanted you could go to a starter off a 96 and up vortec 305/350 for a factory mini high torque starter, which is what I did. I have an extra one of those that I was trying to sell when I thought I could use the 153 tooth flywheel if you need one.
Old 08-08-2016, 01:25 PM   #10
67ChevyRedneck
Thanks man!
If you still have it when I finally get around to it, I might pick it up.
Jesse James
Project "On a Dime"
Old 08-08-2016, 08:04 PM   #11
Shady Rascal
Shady Rascal's Avatar
I expect it won't be long until someone pipes up about that being a weak trans. That seems to be a common occurrence any time someone mentions the 3500. Beats me. I have used them in several trucks and GM thought highly enough of them to build a ton of 350 powered trucks with them and they lived just fine. You'll never hear me speak poorly of one.
Just curious, did you just get tired of the 700R4 and want a manual trans ? Obviously you didn't gain any overdrive advantage from the swap.
Shady Rascal is offline   Reply With Quote
Old 08-08-2016, 08:54 PM   #12
bluex
bluex's Avatar
I'm not worried about the strength of the trans. I'm sure a vortec 350 has more power than my truck does. I'm aware they aren't the best but they fit my budget an that is what matters the most. I've had this trans kicking around for 8-9 yrs an from what I remember I picked it up for about $200.
I've wanted this truck to have a manual trans since I learned to drive one. There was nothing wrong with 700 I was just finally ready to do the swap. At the time I put the 700 in it I didn't have the place or the time to have it down long enough to do a manual swap.
Old 10-28-2016, 07:23 PM   #13
zero6-dc
zero6-dc's Avatar
I am Tony. I thought I was the only one sorting the same issues. I am so glad I found your post. I have a 79 stepside with a Ramjet-502 crate engine and a T-56 for transmission. I am going to follow your example for the clutch pedal, unless I can find an aftermarket to fit. And regarding the factory crossmember, I have mine in-place. Bear in mind I have had this truck since brand new. Originally w/305cu in small block and th350, It seems to fit 427 BBC w/350 (mod.) then BW 4-speed and now the T-56. I am currently cutting my floor driveline and alignment issues. As we speak it looks the crossmember will work yet again.
Thank you again for your post and info.
Tonyd.
zero6-dc is offline   Reply With Quote
Old 10-28-2016, 09:19 PM   #14
lilpoindexter
lilpoindexter's Avatar
Very cool. I put a hydraulic clutch bellhousing in my '78 when I swapped in a T5. i used a hydraulic master cylinder from an '87 chevy truck, and it looks goofy because the firewalls aren't the same between '78 and '87....so the master is at a slight angle. Your solution is much cleaner.
lilpoindexter is offline   Reply With Quote
Old 11-02-2016, 09:56 AM   #15
bluex
bluex's Avatar
Tonyd.
No problem man, glad it was helpful. As I mentioned in that section I based all my hydrualic selections off what others have done for a T56 since its the same slave/bearing for both transmissions. You can follow what I did and it should work perfectly.
Thanks!
Old 11-02-2016, 10:38 AM   #16
HunterRotten
HunterRotten's Avatar
My dad and I did this swap and the transmission kept screaming in all gears and was leaking everywhere from both ends so we ditched it pretty quick. Using the same setup with a TKO 500.
HunterRotten is offline   Reply With Quote
Old 07-23-2018, 12:35 PM   #17
SBTork
Garage wrench
SBTork's Avatar
So for the pedals....did you use a willwood clutch pedal or did you use stock mechanical clutch pedal? I wasn't sure from your original post and may have missed it.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 07-24-2018, 08:55 PM   #18
bluex
bluex's Avatar
It's a modified stock mechanical linkage pedal
