12-20-2018, 10:51 PM | #1 |
What mufflers Are you using?
I have long tube headers and chambered mufflers on my sbc 69 c10.
Thinking about going to glass packs right off the headers. What are all of you using? Last edited by LockDoc; 12-20-2018 at 11:13 PM. |
12-20-2018, 11:19 PM | #2 | |
The Older Generation
Re: What mufflers Are you using?
I am using Hooker cast iron headers and Flowmaster Series 40 knockoffs with pipes all the way back on the Panel Truck. They had a bad drone at about 60 mph so I added "J" pipes behind the mufflers and it sounds great now. LockDoc
12-20-2018, 11:26 PM | #3 |
Excuse my ignorance......what is a J pipe?
12-20-2018, 11:44 PM | #4 |
Short pipes that are shaped like a "J". They weld into the exhaust pipes behind the muffler. They have to be a certain length depending on what RPM the drone occurs. If you type J pipe exhaust into Google it will explain them.
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-24-2020 at 10:51 AM. |
12-21-2018, 01:52 AM | #5 |
Wow, I had no idea.....I'm 56 years old and have never heard of that!
I didn't google it but does the tone change much? Thanks Locdoc! Blake |
12-21-2018, 01:31 PM | #6 | |
Here is a chart to calculate the length you need. You can't just make them any length and expect them to work. That's why I recommend doing some reading on them. I think mine are 23.5 inches long. LockDoc
12-21-2018, 09:36 AM | #7 | |
Personally, I want to make good power and be more quiet these days. I’m running Dynomax Hemi Turbo mufflers on my Jimmy and have a second set for my short step when the big block goes in. I have a set of Jones Turbo Tubes attached to the end of the headers on my AMC 360 in my CJ-5 and that’s always enough to remind me what I don’t want in my truck!
12-21-2018, 01:36 PM | #8 |
I think you can count on a pretty annoying drone with that combination. If you like noise it should work well.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-21-2018, 01:42 PM | #9 |
I'm running 3" spintech mufflers, x pipe, hooker headers. It's little loud for me from the inside, but I like the sound from the outside.
https://www.youtube.com/watch?v=J5CxfMAJR5U For a more mellow tone, I've heard great things about Magnaflow mufflers. |
12-27-2018, 02:34 PM | #10 | |
12-27-2018, 06:55 PM | #11 |
whoops, forgot to specify. 3000.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
12-27-2018, 09:48 PM | #12 |
70+ ( Old Skool Club )
I put these on my bone stock with factory ram horn exaust manifolds and an H pipe with 2 1/4 inch pipes exiting behind the rear wheels to the side. Seem a touch loud til they warm up then nice mellow tone for normal driving butreally bark when accelerating hard. No drone at Highway speeds.
http://www.dynomax.com/catalogsearch/result/?q=17747
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-27-2018, 10:25 PM | #13 |
laying low
I would like to see the Revolver Magnaflow truck in person. You know all those muffs sound much different than on video.
12-27-2018, 10:55 PM | #14 |
I'm thinking of going with the same mufflers as my Camaro. Got a little rumble under normal driving, when you put your foot in it they have a valve that opens and it comes to life. I'm sure they'll sound different without the LS motor but kinda the best of both worlds for me.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
12-27-2018, 10:59 PM | #15 |
That Does sound great. It's a big block so will sound different than small block in tone.
Nice truck! Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
12-27-2018, 11:45 PM | #16 |
Like the other guy on here with Spintech's said, they're annoyingly loud on the interior. Magnaflows with electric cut outs would be my preferred choice, next time.
12-28-2018, 12:05 AM | #17 |
Another interesting option: BBK has a muffler you can manually adjust the sound. Like having 3 mufflers in one.
https://www.bbkperformance.com/3-in-...uminized.html#
12-29-2018, 06:36 PM | #18 |
Sawlog ;my mufflers are the round 3 inch straight through style, with Sanderson short headers,if you go onto you-tube you can listen to many different manufactures muffler sounds.
12-21-2018, 03:28 PM | #19 |
I wonder how J pipes compare to a resonator?
I'm running some kind of Turbo mufflers. Think they are Hookers. I've run turbo mufflers in just about everything I put performance exhaust on. I really like them. Much better sounding than stock, but still quiet enough for a daily driver.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
12-24-2018, 11:16 AM | #20 |
Are you trying to make everyone hate you and give yourself a migraine every time you drive it?
Anyway, what's your end goal for sound? Aggressive? Tough, but subtle? Vintage 60s-70s sound? Smooth idle and cruise, but really talks at hard throttle? Piss off your neighbors at 6:00 AM?
12-24-2018, 11:43 AM | #21 |
I really like my big DynoMax. Quiet and low-toned at idle, NO drone at cruise, but loud and angry when under load. Seems like the best of all worlds.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
12-25-2018, 09:17 AM | #22 |
Ive got headers and had a set of turbo mufflers, sounded pretty good but a little on the quiet side. When I did my engine swap, i swapped out for a aet of hooker max flows. The performance is there, but still rather quiet and wimpy sounding?
Posted via Mobile Device |
12-25-2018, 11:20 AM | #23 |
1970 c10
350cu TH350 auto Mostly stock engine with a few upgrades Summit ceramic long tube headers Custom 2 1/2" exhaust Flowmaster 40 series delta flow H pipe Pipes come out under bumper No drone at all. Not too loud. Rumples nice at idle Barks when you step on it. Normal driving you can hear radio etc. not obnoxious. A couple videos of the sound. Quiets down after engine warmed up too https://m.youtube.com/watch?v=Q4hRlBLtOng https://m.youtube.com/watch?v=s4iNCxKl8RA
12-25-2018, 12:04 PM | #24 |
My challenger has flowmasters and is screams a lot (loud) and my c10 402 has magnaflow and they are perfect
12-25-2018, 06:31 PM | #25 |
on my 509 merlin3 I'm using Dynomax ultra flo round.I shake my neighbors coffee cup when i drive by his house.
