01-11-2019, 09:16 PM | #1 |
WTB...suburban clamshell parts
I wanted to see if anyone has a lower seal plate that goes from side to side for a clamshell gate to bolt onto available in decent condition. Preferably local but would entertain shipping items also. I am switching my suburban over to clamshell from Barn doors and these are the last items needed. I've attached pics of were the parts would be. Thanks
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors 2007 chevy 2500 hd 4x4 duramax Last edited by lownslw64; 01-18-2019 at 07:12 PM. |
01-15-2019, 01:15 PM | #2 |
Re: WTB...suburban clamshell parts
ttt
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors 2007 chevy 2500 hd 4x4 duramax |
01-16-2019, 03:23 PM | #3 |
I should have a spare set of the Chrome tailgate supports but they are not cheap if you haven't found that out yet - 200 a set.
Also, do you already have the clamshell upper liftgate supports? they are even higher but I think I have one
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
01-16-2019, 04:20 PM | #4 |
let me clarify a little bit for the hardware that is needed for the lower gate. I don't need the tailgate supports I just need the part that goes above it that the lower gate will latch to. here is a pic from another burb I found. I have both the lower gate and upper gate supports.
01-17-2019, 11:06 AM | #5 | |
01-16-2019, 10:28 PM | #6 |
I probably have those catches. With the storm tomorrow I can't check until Friday, but I'll let you know.
01-17-2019, 10:25 AM | #7 |
ok, thanks for looking everybody!
01-18-2019, 03:43 PM | #8 |
Just checked a couple of my trucks, your top and bottom center barn door catches are the same as left and right clamshell, so you can just relocate them. I have extras if you need them.
01-18-2019, 04:20 PM | #9 |
awesom! thanks for looking and noticing that. i can use mine then.
01-21-2019, 11:00 PM | #10 |
ttt
01-27-2019, 11:35 AM | #11 |
ttt
02-16-2019, 10:32 AM | #12 |
ttt
03-02-2019, 10:51 AM | #13 |
ttt
03-03-2019, 09:24 PM | #14 |
Are they the same as the top and bottom of the doors?
03-03-2019, 09:51 PM | #15 |
Are you asking about the latches? If so yes......another board member let me know that so I am able to use mine from my barn doors.
03-02-2019, 11:05 PM | #16 |
I believe i have those parts will know forsure Monday
03-04-2019, 01:54 AM | #17 |
It's actually the catches that are the same, not the latches. None of the latches interchange.
03-04-2019, 03:11 PM | #18 |
02-10-2020, 12:27 PM | #19 |
