01-26-2019, 08:03 PM | #1 |
Where to put the PCM???
Hi guys,
Where is everybody putting their PCMs on the 64-66 trucks? I have a 65 GMC 5.3 swap going on and I'd like to hide all the wiring but am also adding Vintage Air so space is limited. Please post up your pics and suggestions, thanks! Joe |
01-26-2019, 09:37 PM | #2 |
Re: Where to put the PCM???
Put mine under the seat
01-26-2019, 10:05 PM | #3 |
01-27-2019, 12:17 AM | #4 |
I'd go under the seat if possible with everything..
01-27-2019, 02:38 AM | #5 |
meowMEOWmeowMEOW
Orignally had mine mounted on the inner fender well with fuses etc, but when I rebuilt my truck and ditched the inners, we relocated all the ecm stuff to the passenger upper footwell area. May not be an option since you'll have a/c ducting.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
01-27-2019, 08:23 AM | #6 |
For those that are locating them under the seat on a 64-66 what harness is long enough, aftermarket? Rewired OEM? I would appreciate any pics you have.
Thanks |
01-27-2019, 09:30 AM | #7 |
I don’t have pictures but wiring onder carpet made my own harness
01-27-2019, 12:23 PM | #8 |
I've used PSI on all my swaps...their harnesses have 4-5 ft of wire from the back of the head...I contacted several of the "store bought" harness makers and none would make a longer harness.....with the LS swap being so popular ,you would think someone would offer a long harness...if you build your own you can make it however you want....I know PSI is coming out with a DIY kit...
Of all the engines I've bought I have yet to get the factory harness that wasn't damaged in some way....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-27-2019 at 12:30 PM. |
01-27-2019, 02:06 PM | #9 | |
01-28-2019, 12:28 PM | #10 | |
meowMEOWmeowMEOW
01-29-2019, 10:00 PM | #11 |
01-28-2019, 01:03 PM | #12 |
Almost Satisfied
Call BP Automotive. Their harness is made to put the PCM under the seat. The one for my 71 is more than long enough. The harness is a work of art as well. Labled and easy to install.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
01-29-2019, 10:06 PM | #13 | |
They will also extend it 3' for $100 |
01-28-2019, 03:52 PM | #14 |
Thanks 71 step...Wish I knew that before....BP is one I didnt contact...
and thanks brew...I'll have to remember that next time about a van harness
01-29-2019, 12:17 PM | #15 |
01-29-2019, 10:03 PM | #16 |
Won't there be a lot of water hitting that if driving in a rain storm? I definitely like the clean look though.
01-30-2019, 12:28 PM | #17 |
Potentially, yes but remember that these computers use sealed connectors and they also have a water intrusion rating. I don't drive in the rain on purpose but when I have been caught in it, it hasn't been an issue. They get doused with water all the time in 4x4s so it really isn't any different.
01-30-2019, 12:45 PM | #18 | |
meowMEOWmeowMEOW
If your providing a donor harness for rework, anyone will do it the same as a regular truck harness. If your having a harness made, just ask, some will make you the harness instead of just selling a premade truck swap harness for everything.
01-29-2019, 06:38 PM | #19 |
Mounted mine right behind the cluster, right above the parking brake assembly. Fits snug but it fits.
01-29-2019, 10:01 PM | #20 |
01-30-2019, 10:46 AM | #21 |
Almost Satisfied
Here is what mine looks like in a 71.
01-30-2019, 11:17 AM | #22 |
I am mounting mine under the seat. I am using a PSI harness. I can attest that I wish the PSI was about a foot longer. It will work, but the extra wire would have been nice.
My mount is from Motobilt https://www.motobilt.com/product/ls_engine_ecm_mount |
02-01-2019, 09:15 PM | #23 |
can you give me a measurement to compare my harness to so i can see if my harness will be long enough? Mine is from speartech but theres just not really a good way to tell without drilling the hole first i think. Love the utube vids btw.
02-03-2019, 12:18 AM | #24 |
Bolted it to the rad support on the grille side, tucked away nice out of sight. My harness was a 2008 van harness so was extra long but was easy to tuck all the slack wire in under grille/rad support
02-05-2019, 06:46 PM | #25 |
Lengthen a stock harness?
Is it an option to lengthen a stock harness? I assume it would involve splicing to make the PCM end of the harness longer. I like the idea of mounting the PCM somewhere out of the way like under the console/seat or behind the glove box but I assume the stock harness is too short. I've seen them mounted to the inner fender but it's not a very clean look.
