Old 01-26-2019, 08:03 PM   #1
Pontitruck
Pontitruck's Avatar
Where to put the PCM???
Hi guys,
Where is everybody putting their PCMs on the 64-66 trucks? I have a 65 GMC 5.3 swap going on and I'd like to hide all the wiring but am also adding Vintage Air so space is limited. Please post up your pics and suggestions, thanks!
Joe
Pontitruck is offline   Reply With Quote
Old 01-26-2019, 09:37 PM   #2
nsb29
nsb29's Avatar
Re: Where to put the PCM???
Put mine under the seat
nsb29 is offline   Reply With Quote
Old 01-26-2019, 10:05 PM   #3
Pontitruck
Pontitruck's Avatar
And the fuses and relays? Do you have carpet over all the wiring? Any pics?
Old 01-27-2019, 12:17 AM   #4
mongocanfly
mongocanfly's Avatar
I'd go under the seat if possible with everything..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-27-2019, 02:38 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Orignally had mine mounted on the inner fender well with fuses etc, but when I rebuilt my truck and ditched the inners, we relocated all the ecm stuff to the passenger upper footwell area. May not be an option since you'll have a/c ducting.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-27-2019, 08:23 AM   #6
Pontitruck
Pontitruck's Avatar
For those that are locating them under the seat on a 64-66 what harness is long enough, aftermarket? Rewired OEM? I would appreciate any pics you have.
Old 01-27-2019, 09:30 AM   #7
nsb29
nsb29's Avatar
I don’t have pictures but wiring onder carpet made my own harness
Old 01-27-2019, 12:23 PM   #8
mongocanfly
I've used PSI on all my swaps...their harnesses have 4-5 ft of wire from the back of the head...I contacted several of the "store bought" harness makers and none would make a longer harness.....with the LS swap being so popular ,you would think someone would offer a long harness...if you build your own you can make it however you want....I know PSI is coming out with a DIY kit...
Of all the engines I've bought I have yet to get the factory harness that wasn't damaged in some way....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-27-2019, 02:06 PM   #9
nsb29
nsb29's Avatar
5ft mite be long enough
Old 01-28-2019, 12:28 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Ask for the Van harness instead of the truck harness. It adds length to the main trunk of the harness.
Old 01-28-2019, 01:03 PM   #11
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Call BP Automotive. Their harness is made to put the PCM under the seat. The one for my 71 is more than long enough. The harness is a work of art as well. Labled and easy to install.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-28-2019, 03:52 PM   #12
mongocanfly
Thanks 71 step...Wish I knew that before....BP is one I didnt contact...
and thanks brew...I'll have to remember that next time about a van harness
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-29-2019, 12:17 PM   #13
scoot_mcgrute
I've got computer below the radiator and the relays are on the inner fender tucked up against the core support. Makes for a nice and seamless install that doesn't draw a lot of attention to the things that aren't supposed to be there.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 01-29-2019, 06:38 PM   #14
El_C10
Originally Posted by Pontitruck View Post
Hi guys,
Joe
Mounted mine right behind the cluster, right above the parking brake assembly. Fits snug but it fits.
El_C10 is offline   Reply With Quote
Old 01-29-2019, 10:00 PM   #15
Pontitruck
Pontitruck's Avatar
Who sells a converted van harness??
Old 01-29-2019, 10:01 PM   #16
Pontitruck
Pontitruck's Avatar
Must see pics!
Old 01-29-2019, 10:03 PM   #17
Pontitruck
Pontitruck's Avatar
Won't there be a lot of water hitting that if driving in a rain storm? I definitely like the clean look though.
Old 01-29-2019, 10:06 PM   #18
Pontitruck
Pontitruck's Avatar
Called them, they provide 5ft of wire from the back of the passenger side of the intake. My PSI harness for the manual trans I'm taking out is only 4ft so the extra foot may allow it to be mounted under the seat.
They will also extend it 3' for $100
Old 01-30-2019, 10:46 AM   #19
1971Stepside
Almost Satisfied
Here is what mine looks like in a 71.
Old 01-30-2019, 11:17 AM   #20
beaterku
beaterku's Avatar
I am mounting mine under the seat. I am using a PSI harness. I can attest that I wish the PSI was about a foot longer. It will work, but the extra wire would have been nice.
My mount is from Motobilt https://www.motobilt.com/product/ls_engine_ecm_mount
beaterku is offline   Reply With Quote
Old 01-30-2019, 12:28 PM   #21
scoot_mcgrute
Potentially, yes but remember that these computers use sealed connectors and they also have a water intrusion rating. I don't drive in the rain on purpose but when I have been caught in it, it hasn't been an issue. They get doused with water all the time in 4x4s so it really isn't any different.
1966 Army Truck
Old 01-30-2019, 12:45 PM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If your providing a donor harness for rework, anyone will do it the same as a regular truck harness. If your having a harness made, just ask, some will make you the harness instead of just selling a premade truck swap harness for everything.
Back when my ECM and harness were on the inner fender, I drove without a hood to the CarCraft Nationals and got caught in a freaking torrent. The intake tube was less happy, the harness and computer didn't care.
Old 01-30-2019, 08:44 PM   #23
Pontitruck
Pontitruck's Avatar
Thanks guys! I ordered my new harness from BP today. I measured the PSI harness and it is only 48" and now on eBay. I will post more when I get the project more complete.
Old 02-01-2019, 09:15 PM   #24
Putzer
can you give me a measurement to compare my harness to so i can see if my harness will be long enough? Mine is from speartech but theres just not really a good way to tell without drilling the hole first i think. Love the utube vids btw.
Putzer is offline   Reply With Quote
Old 02-03-2019, 12:18 AM   #25
jrusher
Bolted it to the rad support on the grille side, tucked away nice out of sight. My harness was a 2008 van harness so was extra long but was easy to tuck all the slack wire in under grille/rad support
jrusher is offline   Reply With Quote
