09-01-2019, 07:41 PM | #1 |
Need help identifying serpentine setup.
Not the original engine, looking for correct bracket to add air conditioning compressor.
09-01-2019, 08:14 PM | #2 |
Re: Need help identifying serpentine setup.
Bracket is already there, you have a bypass pulley to the left of the tensioner
1988-`1995 brackets |
09-02-2019, 11:41 AM | #3 |
That correct started in 1988
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
09-02-2019, 02:14 PM | #4 |
Those are 88-89 brackets. 88-89 were made out of stamped steel. 90-95 are cast aluminum.
09-02-2019, 02:53 PM | #5 |
09-02-2019, 04:20 PM | #6 |
09-11-2019, 07:21 PM | #7 |
Thanks for all the replies. With the compressor moved to the passenger side, what condenser and manifold hose set should I use?
09-12-2019, 05:53 PM | #8 |
88-91 sbc Burb should work fine.
09-19-2019, 08:20 PM | #9 |
Thanks everyone.
