BMW & ASE Master Certified
Brake line bender tricks
Inline brand 3/16 tube bender
Thought I would share some tricks that I couldn't find when searching... You can bend vibration stress loops.. Basically you start off doing about a 45º rotate a little, 30º and so on till it naturally wants to coil around the handle. but about 30º is the most your going to bend at a time ![]() ![]() While the small tube and a tight bend radius is way stiffer than wrapping/bending it around a 1.5 inch piece of pvc pipe or some can. With the tube nut on, the closest you could make a bend 1.5" to the 0 mark ![]() removed stock handle, found 2 3/8-24 nuts (probably from the 10 bolt rear axle backing plates) and welded them together, the bolt holding it to the die is smaller than 3/8, probably 5/16 which allow a little up and down to center the tube on the die. ![]() ![]() ![]() basically shaves off .5 off the length between the tube nut and bend. all that's left to do is whip up a handle so I don't have to use a crescent wrench to hold the flats of the welded nuts / or a vice. figured someone might find it useful, also doesn't damage the tool! clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
![]() Join Date: Mar 2017
Re: Brake line bender tricks
Nice work. Love seeing people come up with this kind of stuff
67-72 parts collector,…
![]() Join Date: Nov 2002
Great tip.
I think I’ll just build a handle with a hole in it for the tube nut. Thanks for posting
![]() Join Date: Nov 2013
Good idea.......I Like it...thanks!
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
