03-06-2022, 01:24 AM | #1 |
'51 Rusto-Mod
I was asked why some people couldn't find my project build on the site from seeing some of my posts. I guess I haven't had one, so here it is.
Was given the opportunity to buy a 'project' 2 years ago. '52 5 window with alot of parts. Cab was crushed on top. Found a '51 6400 5 window cab replacement. Got the '84 C4 Vette front and rear suspension kit in. Figured out the stock drivers side key lock into the factory latch. Rebuilt the door hinges. Patched the usual big rust holes. Just finished the rear locate fuel tank and filler. Now working on a parking brake setup using the 55+ under dash handle. Goal is to have it look stock, old and worn. My grandfather had a Mobil service station in Laurel, MT and I was told he had a '52 3600 5 window with a fuel delivery tank in the bed, so that is what I'm shooting for...minus the tank in the bed. I will look that old, including patina paint and dents. I already have a show truck that I'm affraid to drive, so this could be a daily driver if needed.
Chip '51 Chevy 3600 5 window C4 Vette front/rear suspension & drive train full Rusto-Mod '92 GMC Sonoma GT VIN #0015 '91 GMC Sonoma GT extended cab 1 of 1 |
03-06-2022, 01:28 AM | #2 |
Re: '51 Rusto-Mod
The fuel filler relocate and the drivers lock pics
03-06-2022, 11:27 AM | #3 |
Re: '51 Rusto-Mod
Glad to see you got a build thread, you do some great work. I'll follow along...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-07-2022, 12:26 AM | #4 |
Re: '51 Rusto-Mod
Worked on fitting the tailgate this weekend.
Have one old rusted original hinge for stock look. Don't know if it's a combo of both replacement new tailgate or new hinges but have 3/8"+ gap at lower part of tailgate. Gives 1/2" space to bed. Will cut and set both sides before re-welding. More reproduction 'identical to stock' parts to deal with.
03-07-2022, 10:45 AM | #5 |
Re: '51 Rusto-Mod
haha, "identical to stock" from 30 ft away.
nice work. |
03-07-2022, 11:25 AM | #6 |
Re: '51 Rusto-Mod
Following alone....
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
03-07-2022, 12:30 PM | #7 |
Re: '51 Rusto-Mod
Gonna be fun..I like the way you did the fuel fill cover inside the bed..that looks good
03-07-2022, 07:54 PM | #8 |
Re: '51 Rusto-Mod
nice work! I dont like it when guys with tanks behind the axle have a filler neck on the floor, even if you dont haul anything invariably you will be carrying something and need gas. I really like your solution!
03-07-2022, 08:54 PM | #9 |
Re: '51 Rusto-Mod
I like the plan!!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
03-17-2022, 11:36 PM | #10 |
Re: '51 Rusto-Mod
Got the tailgate set.
Next to dump the bed outside and back to the cab.
03-22-2022, 07:37 AM | #11 |
Re: '51 Rusto-Mod
that's just satisfyingly tight
04-03-2022, 10:42 PM | #12 |
Re: '51 Rusto-Mod
Got the bed off and finished the front sway bar fitment.
Spent a weekend figuring out the poor movement in the 'Flat Out Engineering' instructions of the sway bar mounting was being they give you enough material to mount the bar on top of the frame for ground clearance(low rider), or below for normal mounting(lol). If they gave you that info, it would save many a headache. Removed 3/8" from the Heim side and 5/8" from the threaded side. That still gives me about 12 threads for anchor between, and it looks like it has normal travel. 1st is no changes, 2nd is cut down to fit. Also installed Heim washers that Flat-out should have included in the kit for a bit more travel in motion without binding.
04-05-2022, 10:16 AM | #13 |
Re: '51 Rusto-Mod
Looking good!! Suggestion though, I would like to see some more support on the frame above the steering rack. Maybe gusset up to shock tower? Just my two cents.
04-05-2022, 09:05 PM | #14 |
Re: '51 Rusto-Mod
It's the full 'Flat Out Engineering" kit.
Frame is boxed in a couple of feet towards the cab also. The only thing I would do different is to box the entire frame for rigidity, but have the brake booster to the frame already. But I don't plan on (at least as of now) rallying it either. Pretty stout I think.
04-06-2022, 03:27 PM | #15 |
Re: '51 Rusto-Mod
you could probably use a slightly softer compression rate on that shock
04-16-2022, 11:59 PM | #16 |
Re: '51 Rusto-Mod
With the chocolate pooping bunny invading this weekend, tried to get something done.
Didn't have any of the stock parking brake hardware so decided to update.
05-07-2022, 11:16 PM | #17 | |
Re: '51 Rusto-Mod
Will install soon.
06-23-2022, 12:12 AM | #18 |
Re: '51 Rusto-Mod
A bit more progress, but not much.
Some more fixing and POR-15 the inner side of the fenders. Dropped the fuel pump and sending unit in the tank and started the thought process of hard line placement. Now I know why hotrod customizers charge so much. Times my brain wants to pop and let out something other than purple dust.
06-29-2022, 07:49 AM | #19 |
Re: '51 Rusto-Mod
Ya most people don't understand how much effort it takes to build or modify something unless they have done it. Just do a bit each day and before you know it you will be done. Don't get overwhelmed.
Your progress looks good though!
07-04-2022, 09:17 PM | #20 |
Re: '51 Rusto-Mod
Started the fuel line runs.
On a staycation this week, so more progress coming.
07-05-2022, 10:42 AM | #21 |
Re: '51 Rusto-Mod
oh man, i could so use a staycation ... git-r-done!
07-18-2022, 11:23 PM | #22 |
Re: '51 Rusto-Mod
Finished the fuel lines and started on the brake lines. Reassembled the heater box freshly painted a week ago with 12v motor and new core.
Still don't think this year is going to be the drive date, but can spend the winter doing detail finish work.
07-19-2022, 11:51 AM | #23 |
Re: '51 Rusto-Mod
great stuff!
10-06-2022, 01:02 AM | #24 |
Re: '51 Rusto-Mod
Been a while since posting but have gotten a bit more done.
Finished the fuel lines and brake lines, including the rotors/calipers.... and now prepping the body and parts for paint. Hoping tho get paint on her before the snow flies, and then spend the the winter re-assembling. Just wishing at this point.
10-22-2022, 11:09 PM | #25 |
Re: '51 Rusto-Mod
Well, missed the weather.
Was on the last wipe down before primer and the rain started. These paint booths are not rain proof. Drip, drip. Now it's in the 40's. Unless it decides to throw in an indian summer, it's done until spring. All put in the shop ready for warmer days.
