06-15-2022, 10:09 PM | #1 |
Disc Brake Conversion With Stock Wheels?
I recently bought a 69 K-10 Chevy, and I spent a few bucks getting the original 15” rally wheels powder-coated and had a new set of 31 x 10.5 tires mounted on them. I’m to the point where I need to get it a shop to get the brakes addressed. I’m fairly positive the drum brakes are shot, and I’d like to convert at least the fronts to discs.
I have done a bit of searching for kits online so that I can supply the parts, but I can only seem to find kits that state they don’t work with stock wheels. Does anyone have any suggestions or tips on what I should be looking for? Posted via Mobile Device |
06-15-2022, 11:21 PM | #2 |
Re: Disc Brake Conversion With Stock Wheels?
What does the barrel look like that goes over the brakes? Got a picture of the back side of your current wheels?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-16-2022, 08:47 PM | #3 | |
06-16-2022, 12:17 AM | #4 |
I believe the "Rallye" wheels started in 1973 so that would have been disc brakes.
06-16-2022, 11:14 AM | #5 |
67-72 parts collector,…
It’s only the pre 71 drum brake steelies that cause issues.
Rally wheels are fine for disc brakes.
