Blue 67
![]() Join Date: Apr 2004
Tire clearance issue
My 67 truck got a hand me down wheels and tires from my 2005 truck! the wheels are 16X8 and the tires are 285/75/16 on all corners on the stock height. I like the shape and the stance but the front tires on both side hit the corner (the red arrow in the pic) when turning. I was wodnering if this is an alignment issue (which my truck needs one) or the combination is just too big for the stock height. Is triming the corners somethig which people do in this case?
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Tire clearance issue
Probably just a combination of tire size and wheel offset. I had the same issue when I first put wider wheels & tires on my K20 many years ago. These trucks being what they now are, I would not advise doing what I did. Grabbed my trusty hacksaw and notched the corners off that area of the fenders. Just an old work truck after all....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Mar 2003
I have 285s on my 68 GMC and they clear without any issues. Looks like we have the same rims. I'm still running the drums, are you?
Blue 67
I have swapped to disc brake many years ago.
I am assuming I have too much caster?!
#5 | |
The tire being almost 33" tall is pushing it @ stock heights.
The Older Generation
I don't know if you have, and there is no guarantee, but new front springs might cure it. 55 year old springs tend to sag a little.... I trimmed the fenders on my '70 Longhorn 4x4. It had new springs but it had 20" wheels & tires on it. I welded small pieces of metal over the opening that the cut created and you couldn't even see it.... LockDoc
![]() Join Date: Sep 2007
switching to disc kicked out your wheels 3/4 of inch each side in not a little more
1967custom |
if cutting the fender is not something you (I would not) want to do...install a coil spring spacer. A 1/2" spacer nets 1" IIRC (2 x the thickness of spacer)
That should raise the fender higher than the crown of the tire way it sits now |
