11-12-2023, 01:37 PM | #1 |
Inherited a 1962 C10 in parts - need some help
I inherited a 1962 SWB in parts (cab VIN shows it was originally a 2wd SWB Fleetside) but the frame is a 4wd. My father in-law bought it in the 80's and took it apart and now I'm putting it back together but want it as a 2wd. The frame seems to be from a 67-72 4wd. Can anyone help confirm the frame year? And is it worth converting it to a 2wd or selling it to someone and buying a 2wd frame? Appreciate any input or help. Thanks!
11-12-2023, 02:00 PM | #2 |
Re: Inherited a 1962 C10 in parts - need some help
62 would have been an X frame, frame is also narrower than other years. Probably hard to find a 60-63 swb frame....frame you have looks like mid 80's
11-12-2023, 02:01 PM | #3 |
Active Member
sell it and buy the correct frame
11-12-2023, 10:44 PM | #4 |
The frame you have is looks to be a 68-72 4wd frame. Definitely worth selling the 4wd frame to someone building a 4wd and picking up a more correct 2wd frame for your truck.
Since you have a 62, the easiest way would be to find a 60-62 frame so the cab and body mounts line up. A later year front crossmember will swap in place of the torsion bar front crossmember if you want to run could. However, you could also use a 63-66 frame, but a little modification would be needed for mounting the 62 body
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-13-2023, 03:17 AM | #5 |
This would be the correct 62 frame.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
11-13-2023, 07:41 PM | #6 |
Thanks for all the replies. I do have access to a 62 rolling chassis but was trying to sort out if it would be easier to convert the frame I have to 2wd or deal with the Eaton HO32 rearend on the 62 setup.
I'll post the 4wd frame I have for sale and grab the 62 frame to get started. Appreciate all the help! |
11-13-2023, 10:05 PM | #7 | |
