Old 02-04-2024, 03:25 PM   #1
57FleetsideC4
LS won't crank
Hi All, I am to the point on my 57 pickup project that I am getting ready to start it. This is a LQ4 DBW with 4L80E trans. I can communicate with the pcm with my tech 2 no coded stored but won't crank. Trans data shows it is in park and have power at the purple wire going out of the switch. There is a start relay and if I cross the big red to purple it cranks. The green wire on the start relay has power and if I touch the yellow wire on the starter relay it then cranks. I also am getting the 2 second fuel pump prime signal. I am really not ready to start it yet but trying to get everything in order when it comes time. Thank You Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 02-04-2024, 04:05 PM   #2
bigmoe
bigmoe's Avatar
Re: LS won't crank
So no power to the start relay when the key is at Start position? You would have to work back from there. Do you have a neutral safety switch in that circuit?
bigmoe is offline   Reply With Quote
Old 02-04-2024, 10:09 PM   #3
57FleetsideC4
Re: LS won't crank
Thank You it does have a neutral safety switch but it is a many wire connector and don't know which pins are for that but the pcm is seeing the car in park so it might be ok. I am going to call the business that sold me the engine/trans/pcm/harness setup to see if they can help. It will probably be something simple. Steve
Old 02-05-2024, 02:13 AM   #4
D-n-Tyke
Re: LS won't crank
These threads may help you if it is the neutral saftey switch on the 4L80 trans. They are from when I was researching how to wire up my NSS.
http://67-72chevytrucks.com/vboard/s...d.php?t=845747
https://ls1tech.com/forums/conversio...l#&gid=1&pid=4
D-n-Tyke is offline   Reply With Quote
Old 02-05-2024, 10:00 AM   #5
57FleetsideC4
Re: LS won't crank
Thank You. I looked at the one with the starter relay and it looks like the dark green wire becomes hot when in park or neutral so I think that part is good. What feeds that yellow/black wire is where my problem must be. Steve
Old 02-05-2024, 01:18 PM   #6
D-n-Tyke
Re: LS won't crank
Are you using the factory fuse box out of the donor vehicle? Or are you using a standalone fuse/relay block as part of the modified LS harness? Similar to this (https://lt1swap.com/fuseblock_obd2port.html)
