#176 |
Re: NJ Suburban
The panel is clamped into position but I'm feeling a bit of a bulge/bow along the top edge. Not sure if I should order another panel and try again or weld it up and break out the shrinking disk.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
#177 | |
The Older Generation
Re: NJ Suburban
LockDoc
#178 |
Re: NJ Suburban
Ran into a problem with the pillar support. Couldn't find any pictures of how it is supposed to look so I welded it up how I thought it should be.
Paul
#179 |
Re: NJ Suburban
Looks good to me! ^^^
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
#180 |
Re: NJ Suburban
Joe check out the problem with the rocker and the quarter alignment posted in the regular forum. Not sure how to make things line up!
Paul
#181 |
Re: NJ Suburban
Ok I can live with this fit!
Paul
#182 |
Re: NJ Suburban
That doesn't look too bad from here. I think it will blend in more when it is all one color too. LockDoc
#183 |
![]() Join Date: Oct 2015
Re: NJ Suburban
That looks nice. Did you shim the rocker out full length?
#184 |
Re: NJ Suburban
It’s shimmed about 3/16 of an inch toward the back and tapering down to zero for about 3 inches. The inner rocker got bent outward to make it even.
Paul
#185 |
Re: NJ Suburban
Finally got it to lay down straight and flat!
Paul
#186 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Re: NJ Suburban
Looks good Paul, was it the bottom lip that was causing the issue?
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#187 | |
Re: NJ Suburban
Paul
#188 |
Re: NJ Suburban
Glad you got it figured out without having to start over. Looking real good.
#189 |
Re: NJ Suburban
Looking good! Thanks for posting the results and how you accomplished such a nice fit!!
#190 |
Re: NJ Suburban
Richard and Joe maybe I spoke too soon. After welding the panel doesn't lay as flat as I'd like. Can't figure out why it is so uneven! I tack welded in between the panel clamps and waited at least 15 minutes before putting down another tack. Nothing overheated and there is still warping. When I lay a flat edge down along the body it seems to start bowing inward two or three inches above the lower panel body line. Anyone out there willing to compare panel flatness in that area to compare?
At around the 60" mark on the ruler the panel starts bowing inward. At the 72" mark the ruler is about 1/8" away from the panel. Is that normal? Paul
#191 |
Re: NJ Suburban
Paul
Did you check it before you ground the welds? Just wondering if it heated up enough while grinding to bow it some? Richard
#192 |
Re: NJ Suburban
I was really careful with the grinding too. It never got hot. I think the warping came from stress on making the panel fit. Looks like I’m grinding this one off and ordering another panel.
Paul
#193 |
Re: NJ Suburban
Well I salvaged 2 weeks worth of work! Figured that it would have to be cut off and a new panel purchased. Also figured I couldn't screw it up worse with that in mind so I got out the shrinking disc on my 4" grinder. I used it to do areas about 4" in diameter and didn't let it get hot enough to discolor the metal. Have to say it did a pretty decent job. At this point the lowest area now is about 1/16" but I'll still work it with a hammer and dolly beror the filler goes on. The straight edge lays pretty flat along the panel and the 3/16" gap I had in my last picture is gone!
Paul
#194 | |
Re: NJ Suburban
I'll bet you are relieved about that! I figured you would try to come up with something to save it.... Glad it worked out for you. LockDoc
#195 |
Re: NJ Suburban
Glad you got it worked out without having to start over with it.
#196 |
Re: NJ Suburban
Good job! Glad you were able to fix it!!
#197 |
Re: NJ Suburban
Truck and garage all prepped for epoxy primer tomorrow!
Paul
#198 |
Re: NJ Suburban
Epoxy done
Paul
#199 |
Re: NJ Suburban
Looks great! It's always nice to see them all one color. Keep up the good work... LockDoc
#200 |
Re: NJ Suburban
Looking good Paul
