11-27-2005, 11:09 PM | #1 |
Sport Mirror Problem - Help !
Bought a pair of repro sport mirrors for our 70 C10. Did a trial fit/measure up before drilling any holes, driver side will be fine. Passenger side measures about 8 inches back from front of door to front hole of mirror, approx factory location, mocked up mirror as high as possible as backing plate will allow before hitting bodyline ridge above it, best location is about 1/2 inch farther back than factory location, as none of the top of the mirror is blocked by the vent window channel.
Even mounted as high as possible a little of the bottom inside corner is still blocked by the door, and a bigger problem is the the mirror cannot be tilted inward far enough to even catch a slight view of the bedside, the mirror nearly hits the base and runs out of swivel at that point. I like to see just the slightest hint of bedside in the mirror for an idea of where things are in relation to the truck. I bought these mirrors from Chevy Duty and they seem to be good quality. Does anyone have any adjustment suggestions or should I try a different brand ? Or is that about as good a view as you (or anyone else) can get with the sport mirrors ??? Any good looking mirror options ??? Thanks in advance.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 11-28-2005 at 12:27 AM. |
11-28-2005, 12:32 AM | #2 |
SWB 4x4 Collector
Re: Sport Mirror Problem
We put my mirrors in the factory location, and actually you can't see out of the passenger mirror. They are hid a little bit behind the vent window and no... you really can't use it, but it's factory. I don't even use it ... it's all for looks. Hope this helps. sorry no adjustments stories here. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
11-28-2005, 02:43 AM | #3 |
The RH mirror is located about 3/4" farther back than the LH from the factory. I mounted my passenger mirror an inch futher back and will probably go another 1/2" when I change out the crappy repop door skin for my NOS one.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
11-28-2005, 03:06 AM | #4 |
okay i know this is an stupid and not meaning to highjack this thread but i hear everyone talking about nos parts what does nos stand for?
11-28-2005, 03:14 AM | #5 | |
11-28-2005, 10:56 AM | #6 |
This truck is going to be daily driven when it's done by my 16 yr old son. Is even the drivers side sport mirror large enough to be any good ??? Not going to be pulling a trailer, how about using the earlier style arms like from a 68 with a 5x7 mirror head ? Would that be much better ??
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
11-28-2005, 12:50 PM | #7 |
I put the sport mirrors on my Burb and agree that you really can't see much out of the passenger side mirror. I have also thought about changing to the '67-68 style (I've heard that they do a pretty good job), but isn't the mounting location in a different spot? I'd rather not drill more holes (not to mention uncovering the ones already there).
'72 Chevy Suburban Custom Deluxe 10, 402/TH400 |
11-28-2005, 12:57 PM | #8 | |
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
11-28-2005, 01:00 PM | #9 |
i'de like to know more about these i got little plastic mirriors the op put on the and if you hit an bumb the driver side moves lol
11-28-2005, 01:41 PM | #10 |
67-72 Addict!
The mirror arms are too short in my opinion. If you put those little 1.5" round spot mirrors on the corner of the mirror it helps alot.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-28-2005, 01:50 PM | #11 |
I got mirrors from the wrecker off 95 Ford ranger (same ones on the Aerostar van). They have a good size mirror and have a lot of adjustment and look good. They were factory black so I painted them to match my paint job.
If you get a pair, watch when you take them off. The two screws go into a backing plate. Don't drop it in the door, you will want it for mounting on your doors. Send me your email if you want pics of mine. Doug |
11-28-2005, 07:19 PM | #12 |
Dork For Days
I recently swapped over to the small mirrors as well. I also had/have the same problem. The psgr mirror is too small to use from that distance. I would like to find something about 50% larger to put on that side, but somehow retain the factory look of the mini-mirrors.
Answer: No, you're no alone. It's bad design.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
12-19-2006, 12:13 AM | #13 |
Do you think part of the problem may be the following is not printed on the sport mirror:
Warning: Objects in mirror are closer than they appear. |
02-19-2012, 10:56 PM | #14 |
" We put my mirrors in the factory location, and actually you can't see out of the passenger mirror. They are hid a little bit behind the vent window and no... you really can't use it, but it's factory. I don't even use it ... it's all for looks. Hope this helps. sorry no adjustments stories here. Trevor "__________________
The Mirrors from brothers won't adjust in either. Where would I find a replacement glass for an OEM sport mirror ? My passenger side mirror is cracked,, probably from the PO trying to adjust it ! I am going to try something on the passengers side swivel ball to try to get enough swivel so I can use it. Any other ideas , answers, or solutions to the " can't turn the mirror in enough " problem would be greatly appreciated !! Thank You ! Tom |
03-26-2012, 03:26 PM | #15 | |
What I had to do, to get the passenger side to swivel enough to be able to see out of it, was to grind the edge of the part that the ball sits inside (the main part of the bracket, not the part that the mirror attaches to). After a couple of trial fits and grinding, it's as usable as it's going to get for the sport mirrors. I also mounted it in the factory location about 8-1/4" rearward from the edge of the door on the pass side. This is a good thread with mounting location info: http://67-72chevytrucks.com/vboard/s...bruce88&page=4 Last edited by LockDoc; 01-08-2021 at 10:40 PM. |
03-26-2012, 10:04 PM | #16 |
Thanks for the tip !! I would like to see a picture if I could . What you described is what I thought I'd have to do .. What did you use for a grinder ?
Thank You !! Tom |
03-27-2012, 12:52 AM | #17 |
WOW this was originally an old thread!
I too had originally bought "sport mirrors" for my truck but after mocking them up I too realized they sucked. I bought a set of 67-70 style mirrors instead. I think they look cooler and are actually functional!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-27-2012, 09:09 AM | #18 | |
Here's a pic of the type of grinding bit I used. I suppose a Dremel and bit would work also. |
03-28-2012, 06:18 PM | #19 |
Thank you for the info !! Looking forward to the pic of the back side of the mirror !!
Thank You !! Tom |
03-29-2012, 07:21 AM | #20 |
Here's a pic of the passenger side mirror (albeit a very poor one) that shows the little lip area that you need to radius. You only want to grind on the stainless lip part that the mirror attaches to, not the ball itself. I think the ball is chrome plated and it would start to rust if the plating is ground off.
It took a couple of trial fits and grinding, the mirror now can turn toward the cab enough so that I can see out of it directly behind the truck. I'm not sure if the original mirrors were this way, the ones I have are repops. Hope it helps. Last edited by 29od1; 03-30-2012 at 07:43 AM. |
03-30-2012, 05:36 AM | #21 |
Thank you for the picture . That took a little finesse to trim that edge without knicking the swivel ball !!! Nice work !!
It's a shame that a person has to remanufacture reproduction parts to make them perform the way they are advertised to !! I returned the repops I had bought,,, the 4 rivets on the back were starting to rust within a month on both mirrors. Thank you for the pic !! Have a great day !! Tom |
04-03-2012, 08:38 AM | #22 |
I had the same problem with my Brothers Repops. I decided that since I will be towing with mine that I would get bigger better mirrors. I went to AutoZone and bought 2 1995 F150 Style mirrors. I like the look and there is plenty of adjustment, plus they are cheap as hell. The mounting point will need to be modified a little but they will work a lot better than the stockers. I have the new in the box set of Brothers Sport mirrors if someone wants them? Make me a reasonable offer.
02-20-2013, 08:09 AM | #23 |
Old thread, but I added the a pic from Bruce's truck build on mounting locations.
Also, you only need to grind the edge of the lip (closest to the door) on the RH side mirror so it can rotate further inward. |
02-23-2014, 04:22 PM | #24 |
Sub'd
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
08-15-2014, 11:17 AM | #25 | |
Thanks. |
