Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-28-2012, 12:15 AM   #1
sunk99
sunk99's Avatar
Tina, A patina 69 burb project
Started a post about this burb over in the message board when I first purchased it a couple of months ago but thought I would start another here as I have begun working onit now. Purchased my Air ride system,dropped spindles,disc brakes,c-notch,ridetech tubular lower control arms and track bar from way2low2 about 3 weeks ago and have been working on it as I have time.I plan on keeping the patina look and fix the major rust areas eventually and restore the interior. I have fired the engine but gas poured out aroud the carburetor,so I had a friend rebuild it and plan on trying to start it when I set it back on the ground (literally). Hope the engine runs good but if it doesn't I will put a vortec or LS in it.I picked up some of my patch panels at the charlotte auto fair along with some other stuff and I have picked up some 15x6 steelies for the front and some 15x8 6 lug for the rear,as I still have to pull the axles to have them welded up and redrilled to 5 lug.
sunk99 is offline   Reply With Quote
Old 05-28-2012, 12:20 AM   #2
sunk99
sunk99's Avatar
Re: Tina, A patina 69 burb project
Here's some pics as I install the suspension.
Old 05-28-2012, 12:27 AM   #3
sunk99
sunk99's Avatar
And a few more.
Old 05-28-2012, 09:42 AM   #4
hotrodchevy1999
Hotrodchevy
hotrodchevy1999's Avatar
nice work that got that burb down on the ground
2017 1500 CREW CAB GMC
1997 C1500 Chevy
1971 CHEVY CHEVELLE SS 402BB :
1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816
My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650
hotrodchevy1999 is offline   Reply With Quote
Old 05-28-2012, 10:11 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Your burb is gonna be cool!
Keith
Convert to disc brakes.
Old 05-28-2012, 11:11 PM   #6
sunk99
sunk99's Avatar
Thanks Guys. Lolife I'm going to try and use the tire sizes you have on your truck. I plan on buying some billet specialties 20"& 22" in the future unless I really like the steelies with the dog dish caps. I gotta get tires this week so I can get it back on the ground.
Old 05-29-2012, 10:35 PM   #7
sunk99
sunk99's Avatar
Couldn't stand it any longer, had to put it on the ground. Ordered the rear tires today and am still waiting on the panhard bar, proportioning valve, and have to pick up some rear shocks. Anyone have a reccomendation for the shocks?
Old 05-30-2012, 12:29 PM   #8
67chevy1series
67chevy1series's Avatar
tina looks awesome! love the stance and the steel rims with caps!
67chevy1series is offline   Reply With Quote
Old 05-30-2012, 01:01 PM   #9
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Dude, that thing is cool
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 05-30-2012, 07:32 PM   #10
hotrodchevy1999
Hotrodchevy
Are you useing a drop spindle and what kind of lower control arm are you useing
1997 C1500 Chevy
Old 05-30-2012, 10:22 PM   #11
sunk99
sunk99's Avatar
Yes,dropped spindles and Ridetech control arms
Old 06-22-2012, 12:25 AM   #12
sunk99
sunk99's Avatar
Finally got my brakes wrapped up tonight, hopefully.Now waiting on a radiator because a socket and ratchet fell between the grille and radiator and knocked a hole in it.
Old 06-29-2012, 11:54 PM   #13
goldenburb
goldenburb's Avatar
I like it, now how dose it ride?.. mine rides like crap.
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 07-13-2012, 10:21 AM   #14
sunk99
sunk99's Avatar
Haven't gotten to drive it yet,I've had too much going on hope to find out soon.
Old 01-21-2013, 06:16 PM   #15
sunk99
sunk99's Avatar
It rides pretty good.
Old 01-21-2013, 06:49 PM   #16
sunk99
sunk99's Avatar
I was able to take the Burb to the Grand Rod run in Pigeon Forge and enjoy it a little before bringing her home and pulling her apart to send over to my buddy's to have all of the major rot cut out and replaced. My intentions are to leave as much of the original patina as possible and re-create it where panels had to be worked. It will be my first attempt at this so any pointers will be appreciated.I also picked up a 5.3 engine for it and will be addind that to my list of things to do after doing the body and paint work.I have purchased Trailblazer SS manifolds,a Boyd EFI tank and ECE mounts for the conversion so far.I also found a good radiator support,new inner fender wells and an aux. battery tray to move the battery to the drivers side.Sorry for the long delay on updates but I've been busy with work,researching info for the engine swap,life etc.I'm sure everyone knows how it goes. Also been watching everyone elses awesome builds on here and trying to retain some of the knowledge you share,Thanks by the way. Ok enough of the chatter I will share some pics now.
Old 01-21-2013, 07:13 PM   #17
goldenburb
goldenburb's Avatar
So what shock did you go with?? IT'S coming together nicely..
67 c10 2wd sb truck
67 c10 4wd lb truck
Old 01-21-2013, 07:15 PM   #18
hopped up
hopped up's Avatar
I really like it with the white steelies it has now
hopped up is offline   Reply With Quote
Old 01-21-2013, 07:40 PM   #19
sunk99
sunk99's Avatar
I think they were monroe.
Old 01-21-2013, 08:32 PM   #20
sunk99
sunk99's Avatar
More pics!
Old 01-21-2013, 08:36 PM   #21
sunk99
sunk99's Avatar
More
Old 01-21-2013, 08:49 PM   #22
sunk99
sunk99's Avatar
More again
Old 01-21-2013, 08:54 PM   #23
sunk99
sunk99's Avatar
more
Old 01-21-2013, 08:57 PM   #24
sunk99
sunk99's Avatar
Whew
Old 01-21-2013, 09:12 PM   #25
sunk99
sunk99's Avatar
A few more
