08-21-2013, 10:34 AM | #26 |
Re: Tuff country 4" lift. Pinion angles?
Those are brand new springs unweighted. They will settle some and when you put the rest of the truck on it. How much is hard to say.
Posted via Mobile Device |
08-21-2013, 10:51 AM | #27 |
it will come down significantly under the weight of the truck body. it looks fine to me.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
08-21-2013, 11:38 AM | #28 |
Pinion angles are irrelevant at this stage also
08-21-2013, 01:57 PM | #29 |
Gotchya thanks again guys
08-21-2013, 10:01 PM | #30 |
Correct me if I am wrong but I don't think the pinion angle will change when weight is added to the frame?
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
08-21-2013, 10:43 PM | #31 |
As the shackle rotates it changes the angle of the axle. Depending on the at-rest angle of the shackle the angular change of axle will be smaller or greater.
As was previously mentioned, I wouldn't mess with adjustments to pinion angle until you get the truck at final ride height. Posted via Mobile Device
10-01-2017, 08:18 PM | #32 |
old post, nice info. originally the rear end in my 69 gmc had tapered blocks, i left them out and now its binding, so i jacked up the pinion end 1'' and it dont bind now. guess i better get them back in? it also has a 4'' lift now. any input here?
10-05-2017, 08:16 PM | #33 |
They look short... Did you measure your stock springs? that era trucks had 52 and 56 inch springs. might have been 52 and 54inches
