Old 09-29-2014, 03:23 PM   #101
no1udknow
no1udknow's Avatar
Re: jimbosprint 1972 C20 - the good, the bad, and the ugly
Originally Posted by jimbosprint View Post
That's pretty cool, but I'm about out of money to spend on this for at least a while.
Yeah, I'm with you on that one... why do you think my status updates have slowed down so much. -$. I have an hei distributor at home that will be going on the truck, and eventually so will ome of those corrected caps. My 99 Tahoe had one on it from the factory, and I really liked it, but the disteibutors themselves were junk, they were plastic and if you tightened the cap too much, the mounting ears snapped off. When I got my tahoe it had a zip tie holding the cap on. I used to twll people it lets the cap wiggle for variable timing ;-)
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 09-30-2014, 10:31 AM   #102
jimbosprint
jimbosprint's Avatar
Photo gallery updated (210 photos!). Link in sig below.
jimbosprint is offline   Reply With Quote
Old 09-30-2014, 01:32 PM   #103
no1udknow
no1udknow's Avatar
I just browsed your web page, didn't know you had a nova, I will have to post up a pic of our 73 SS.
Built not bought!
Old 09-30-2014, 01:44 PM   #104
jimbosprint
Awesome. I sold mine 8 years ago. Waaaay too long to go without a classic Chevy! I loved that car, and I want to make this truck even nicer.
Old 10-01-2014, 12:27 PM   #105
jimbosprint
The truck with no name
Old 10-01-2014, 12:29 PM   #106
no1udknow
no1udknow's Avatar
I think you should put the good by top pic, the bad, by engine pic, and the ugly by the dent ;-) and do ot left right left
Built not bought!
Old 10-02-2014, 08:25 PM   #107
jimbosprint
At least I got something done today. I replaced the resistor wire that went from the bulkhead connector to the old coil with a nice healthy 12 gauge wire for the new HEI distributor.
Old 10-02-2014, 09:40 PM   #108
Saclandman
Saclandman's Avatar
I think I need to do that too. HEI would be nice.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 10-02-2014, 11:27 PM   #109
no1udknow
no1udknow's Avatar
me too, I have a distributor already that I have been sitting on for a while, time to put it to some use
Built not bought!
Old 10-03-2014, 12:13 AM   #110
jimbosprint
$90 for HEI from Summit. http://www.summitracing.com/parts/sum-850001r/overview/
I had the same one in my Nova and it worked well.
Old 10-03-2014, 12:54 AM   #111
Saclandman
Saclandman's Avatar
Did you get the whole combo kit or just the distributor? Just wondering if the extra $30 is worth it for the kit.
Rich J.
Old 10-03-2014, 01:08 AM   #112
jimbosprint
I just got the distributor. I think it was ~$45 for wires from Napa for wires that will work under the stock exhaust manifolds (I asked for wires from later 70s).
Not a bad deal for the kit if you can use those wires.
Old 10-04-2014, 08:28 PM   #113
jimbosprint
Got a couple more little things done today while the paint on the block cures competely.
The transmission crossmember was re-installed into the frame. Amazingly, it went back in a lot easier than it came out (and I didn't even get that dirty).
I got the alternator fan and pulley painted to match the rest of the pulleys and brackets.
I also got a few timing marks painted on the balancer. 0 is marked to use the stock timing indicator, and 30-32-34 for total advance timing.
And I removed the redneck cruise control next to the gas pedal that had some evil 2" screws going through the firewall.
Old 10-04-2014, 08:39 PM   #114
Xeen
Xeen's Avatar
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-06-2014, 09:01 PM   #115
jimbosprint
The plan is to put the motor in on Wednesday!
Old 10-07-2014, 02:16 PM   #116
jimbosprint
Got a few things done this morning. So excited to get this running that it's hard to sleep.
Old 10-07-2014, 04:30 PM   #117
swamp rat
swamp rat's Avatar
Hey can you post the part number's on the manifolds for me please? Thanks.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-07-2014, 04:42 PM   #118
jimbosprint
LH - 39324?9 (could be a 3, 6, or 8)
RH - 3905364
Old 10-07-2014, 07:51 PM   #119
flashed
Wow ,looking good ,keep it up.
flashed is offline   Reply With Quote
Old 10-07-2014, 08:16 PM   #120
jimbosprint
Disaster. The block is missing a hole drilled for one of the plug wire shields. I don't know what to do. I will take them all off if I can't use this one. Ideas?
Add to that some LMC incompetence.
"This part you sent me doesn't work, can I exchange it for a different part?"
"Okay, sir. Please email us a photo of the part you need."
"Photo sent. Do you have the part I need?"
"Customer service will look at the photo in a day or two and get back in touch with you.
"Thanks!"
Couple days later I get an email that says they shipped something. I call and ask if it is the part I needed.
"I don't know sir. All the account says customer service took care of it and sent you new parts."
New parts arrive today and are exactly the same part that I got the first time, not the part I asked for or sent a photo of.
Also, thanks for insulating this cartoon plug loom so I can only use 2mm wires on it.
Old 10-07-2014, 09:28 PM   #121
jimbosprint
Crate motor regret. Wish I had spent the extra money on rebuilding the original engine.
Old 10-07-2014, 09:33 PM   #122
Xeen
Xeen's Avatar
Keep in mind you have a new crate motor and it isn't going to have the same configuration as a small block from 45 years ago so your heat shield bolt holes aren't going to be in the same place, in fact you may not even be able to use heat shields that bolt to the block at all, you might have to use the style that bolts to the exhaust manifold.
Old 10-07-2014, 09:43 PM   #123
jimbosprint
I'm putting the motor in tomorrow without the heat shields. Maybe someday I can fabricate (or get someone to fabricate) something to make it work. If I come into a pile of money though I'm putting it into rebuilding the original block.
Old 10-07-2014, 10:08 PM   #124
Xeen
Xeen's Avatar
Honestly the metallurgy in the new crate motor is so much better than the old 60's-70's small blocks it's not even funny, you have the better deal with what you have you just need to figure out a solution and trust me it's out there.
You will burn up your spark plug wires very quickly unless you shield and route them properly then you will definitely be unhappy, don't give up so easily.
The local machine shop will know in 2 seconds what heat shields you need with that block/exhaust manifold combination so load up the engine and take it down there, they will probably even have them in stock and sell them to you.
Old 10-07-2014, 10:34 PM   #125
jimbosprint
I haven't given up. I know the engine will be good. Thanks for the support.
1972, c20, deluxe, stock
