![]() Join Date: Oct 2011
Dana 60 question
I've looked all over the World Wide Web and cannot find any answers on application of part numbers
Left hand steering knuckle cast number c41896 and c38138 , are these the same ? Will either fit 1990 gmc v3500 ? Thanx in advance ![]()
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
Re: Dana 60 question
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
If it has 6 bolt spindles then yes. Ford used 5. GM and dodge are pretty much the same.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
#4 | |
dodge = middle of knuckle for casting ear for tie rod. gm = lower area of knuckle for casting ear for tie rod. but yes they can swap otherwise .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
https://www.ebay.com/itm/CUCV-GM-Dan...xaQrXD&vxp=mtr
this is correct for your v3500 they do appear to be interchangeable.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2 1991 V3500 350/4l80/205 60/14 4.10 35 toyos. |
#6 | |
Price is good
It fits. You're fine.
