11-19-2007, 07:55 PM | #1 |
Transfer case torque mount
OK, I'm an idiot... Dropped the t/c with out paying attention to how the torque mount goes back together. I looked in my assembley manual and the service manual, just one very small pic in it, not much help. Checked out the FAQ's no help. Seems like it's simple enuff, but it doesn't look right when I put it together.
Any pics. or help. pls....
11-19-2007, 09:04 PM | #2 |
Re: Transfer case torque mount
I can get you a pic tomorrow if no one else has by then.
11-19-2007, 09:39 PM | #3 |
Thank you, no hurry. I can mount my crossmember back up without the torq mt. Maybe I should post up a pic. to show you the way I think it goes
11-19-2007, 10:21 PM | #4 |
you are talking about the side mount right, just did mine today, no pics but I'll try to explain the way mine went together. starting from the bottom- larger of the two halves of bushing, then a plate, then the main body of the bracket then the upper bushing and the center sleeve holds it all together. The plate mates right into the body, the curve of the holes match up. hope this is what your looking for, kind of hard to explain.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
11-19-2007, 10:32 PM | #5 |
ran out and took a pic for you, I am still in the bare frame stage
11-20-2007, 12:08 AM | #6 |
It's the air up here
http://67-72chevytrucks.com/vboard/a...1&d=1195531633
NP 205. Hope this helps.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c Never drink down stream of the herd! Eric |
11-20-2007, 08:09 AM | #7 |
Thanks for the help guys, although I am still concerned. Seems wierd that they would have metal to metal on the oval pc. with the 2 holes in it.
Also the ID of the sleeve that goes in the urethane bushing is a little large compared to the original sleeve. Should I worry about this or make another sleeve to match the original specs. I just rotated the oval plate 180 degrees, and the space between seems to match up better, in the pic you can see the gold anodize... I would have put the thicker urethane pc. on top...anyway here are some pics.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-20-2007 at 09:54 AM. |
11-20-2007, 09:38 AM | #8 |
Who did you get your mounts through? I have to get mine soon and the only place that I have seen them was LMC.
11-20-2007, 09:49 AM | #9 | |
Torque Mount bought at Summit, Prothane 1603, Prothane doesn't carry trans. mounts, only '73 and up. Could be wrong on the part number, so check it out Hope this helps. J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-21-2007 at 01:19 PM. |
11-20-2007, 11:23 AM | #10 |
That's not how mine went together. The plate fits into the other main bracket. kind of doubles up the metal so to speak. when the two are placed together they are right next to each other stacked together like if they were going to make a solid piece of steel rather than two separate pieces.
11-20-2007, 11:40 AM | #11 |
Ace, how's this look...
11-20-2007, 11:47 AM | #12 |
Ya, like that. I was trying to post a drawing for you-
11-20-2007, 11:49 AM | #13 |
sorry, my drawing had the lips the bushing fits into going the wrong way.
11-20-2007, 12:02 PM | #14 |
Hey Ace, your drawing is way better than I could have
Thanks for the help, just finished mounting T/C back onto crossmember. Trying to get it back up into the truck... My only concern now is the ID of the sleeve, I'll call Prothane tomorrow and see if they can help Later J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-20-2007 at 12:05 PM. |
11-20-2007, 12:09 PM | #15 | |
11-10-2011, 11:20 AM | #16 |
Anybody have an idea of where I could buy the "thin plate" or oval piece?
Thanks, Matt |
11-10-2011, 11:37 AM | #17 |
Windy Corner of a Dirty Street
Everybody has an opinion but if it were me, I would take that transfercase side mount off and throw it in the trash, especially if you are pumping any respectable power out of the engine. Those side mounts are only good for breaking trans to tcase adapters and cracking bellhousings on automatic trans equipped rigs.
Recent thread on this same topic. http://67-72chevytrucks.com/vboard/s...d.php?t=491001
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
11-11-2011, 11:33 PM | #18 | |
Larry, didnt the K case TH350 have rods from the flywheel cover up to the motor mounts
11-12-2011, 01:02 AM | #19 |
I don’t recall those rods on TH350’s but 700R4’s in many years of pickups and G-vans had those rods from the torque converter dust shield up to the engine mount brackets.
11-12-2011, 12:48 PM | #20 |
Yes they do my Blazer has those rods
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
11-12-2011, 01:06 PM | #21 | |
11-13-2011, 04:33 AM | #22 |
Before you even reinstall it, you may want to check out this thread
http://67-72chevytrucks.com/vboard/s...62#post5005462
1968 K10/30 Frame Off Project "Overkill" My 5 year, $30,000.00 toy |
11-29-2015, 11:09 PM | #23 |
hey guys. i have a 1979 k10 and i cant find this torque mount, side mount, strut brace its been called so many different names but i cant find it anywhere. im running a 205 with a th350 and that mount was not on the T case. i was driving down the road and the weight from the T case binded up the u-joint and snapped that off allowing all the weight from the T case to bounce around and it cracked my tranny housing. if anyone knows where to find this mount please send me a link or a general website. thanks
11-30-2015, 10:16 AM | #24 |
Some np205s are not drilled for the brace if you look at the passenger side of the case by theframe rail the will be a flat spot with two dimples or two threaded holes if its drilled and tapped my 205 is out of a 78 and isn't drilled so yours may not be either the np203 and 208 also had a arm that went from that point to a belllhousing bolt on auto trans trucks I'm not for sure if the 205 got the same treatment in an auto rig though
11-30-2015, 07:20 PM | #25 |
I have a 78 3/4 ton 205 in my K5 and it does not have the boss drilled for the support brace.
