alright guys..restoring my 82 short bed and in the process of deciding on amount of drop. need to see your lowered 73-87 short beds and the specs(how you got it there). was possibly thinking of doing a 2-4 drop or 2.5-4 i guess if i were to use drop spindles in the front, shackles and hangers in the rear, but not sure if it will be enough. your input will be of great help...oh yea, let er riiiiiiipppp!
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Lowered 73-87 Short Beds
Go directly to the 4/6 drop.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
Always liked where this thread was goin
http://67-72chevytrucks.com/vboard/s...ht=Drop+thread
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
lolife99..is that what you have on the sweet red ride on your profile? the 4-6? suggest prob a flip kit for the rear? i imagine its a must..
![]() Join Date: Dec 2008
#8 | |
I suggest the 4/6 for the 73-87 trucks because it's a very streetable combination. The flip kit is easier and cheaper. No c-notch needed. (unless you go with a 5/7 drop) I'd use Belltech or Western Chassis components. Drop spindles, Springs, Flip Kit, and a good set of drop shocks. Also, a front sway bar is a cheap mod,... if you don't alreay have one. If you do,... just add a set of Energy Suspension bushings,... and it will work fine.
![]() Join Date: Jul 2009
Here's a couple of shots of my ole '87. It had 2.5" drop spindles and a 1" drop coil with a 1/2 a coil cut off (for a total of 4.5" in the front) and just a flip kit in the rear. I used the 2.5" spindles so I wouldn't have to grind on the lower control arms to be able to run my stock 15x8 rally's without any rubbing issues. It road GREAT
Like suggested above, I would go right to a 4/6. Most people will want to go lower even from there. I did a 3/3 on my friends truck we rolled it out of the garage and not even within 10 mins of seeing it he already wants it lower.
Mines a 6/8.. ![]() |
2.5 front and 3.5 ish on the rear
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622 |
Badass
im starting to like the dumbos
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
sick pics fellas! thanks for the advice...i was originally thinking the 2-4 might be a little much, but last thing i want to do is lower my 82 and instantly wish i would have gone lower. plan is to go back with the original 8 inch rallies for now(not the ones in profile pic), and the 4-6 looks to be the way to go. keep them pics rollinnnnnnnnn'..
All About the BOWTIE
One coil cut from the front...
Overloads taken off the back...
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... |
#15 |
Cruzzzn' Vet
#16 |
Laid back freak
Once i put the bed on my truck ill take some snap shots.I put 2 1/2 inch westin drop spindles w/ 2 inch coils.In the rear i did a 5 inch flip kit w/ a 2 inch drop leaf from bell tech, so i got a 4 1/2 in the front n a 7 in the rear..Running 18 inch coys in the front n 20s in the rear..
thanks pat
1980 chevy c10 step side restomod, ![]() 1970 cougar convertible 1 OF 24 ever built: 2014 Hyundai Tucson limited (daily driver). |
#17 |
3/4 and lovin it
#18 | |
Chris
which is the overload? the shortest bottom one that's flat?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
#19 |
^^^I was thinking the same thing. It looks a lot lower than it should be for that little bit.
Posted via Mobile Device |
#20 |
HEY MALO83
What size tires are you running? I need to cut the front coils On mine my truck has air shocks on the back but the line blew off ![]() I like the way it sits in the rear but now the front needs to come down a bit Also how does tour ride with the coils cut? do your tires rub in front? Thanks Jeff Main |
#21 | |
81 chevy stepside 6.0/t56 swap in progress.... ![]() 81 chevy silverado k5 2wd 350 tpi and 700r4.. SOLD 07 chevy colorado "work truck" SOLD 02 chevy silverado z71 off road package |
#22 |
6.0 powered square
5-7 3" djm spindles and springs and beltec flip kit and drop shackles, going back to a 2/3 in a few months
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 10-07-2010 at 11:53 PM. |
#23 |
Good Lord! Your truck is gorgeous!!
Jesse. ![]() |
#24 |
hey guys..got the ole original rear end swapped out to a 3.42 posi, so now ready to order flip kit for the rear so she can be bolted all back together. have decided to go with the 4/6. lolife99/nlped would you guys suggest the following?
http://www.stylintrucks.com/part.aspx?partid=19397 do i need the c-sections/shock relocators or can i get by without? however, if it means sacrificing ride quality i will definitely spend the dough. last thing i want is a low/stiff ride i cant even enjoy...if you guys have any other links or advice please hit me with them. |
#25 |
Badass
wouldnt buy from them. many guys have had problems with them. i got mine threw summitracing with no problems
and 6inch you need a cnotch. 5 inch you dont
Tags |
73-87 chevy truck, dropped, lowering, slammed |
