71 C10 6.0 LS ground up build
Finally bought myself a c10 about five weeks ago and drove her home. This brings back great memories of my first c10 i owned in high school and my first date with my now wife of 19 years. Couldnt wait to get started on the ground up build. A good friend and i got it tor down to rolling chassis on a friday night now the fun begins.
Re: 71 C10 6.0 LS ground up build
Got frame all done and previous work of shortening frame redone before powder coating. Sent frame out for chassis black powder coating along with front end componets.
![]() Join Date: Nov 2010
Watchin
Got roller assembled used eec 4/6 drop kit with there trailing arm crossmember and gen 3 ls mounts. Got rear shocks relocated and pan bar from eec setup. I rebuilt entire rear differential and installed 3.73 gears with yukon posi unit. Sand blasted and painted rear diff.
Awesome start! Hang tough.
Awesome! Watchin.....
Had some time with the holiday weekend so I rebuilt a 4l60e with heavy duty sprag sunshell and 5 pinion planetary gears. Used a transgo shift kit and high energy clutches. Painted and clear coated trans and installed aluminum pan. Got brake lines ran and flared. Feels good to have a major componets finished!
Been awhile since I updated the build. Took lq4 engine apart and had valve job done. Installed a z06 corvette camshaft and valve springs. Assembled and painted motor. Ready for install now
Keep up the good work... Just finished my LS swap and let me tell you,,, you want regret it once your done and have all the demons worked out...Casey
Thanks. If you don't mind send me a picture of where you put ecm and hoe it looks under the hood!
![]() Join Date: Jun 2012
Looking good so far
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
![]() Join Date: Jun 2009
Awesome build, progress is looking great
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
Another- you made that look easy. Quick work, Chassis Looks fantastic. Carry On.
Thanks guys slowly but surely getting there.
#15 |
Got motor and transmission sitting in frame last night now cab needs to be set back on for mock up of ac etc.
#16 |
![]() Join Date: Oct 2009
Very nice build! You are getting busy and doing a great job!
Justin 71' C10 SWB 00' Dakota R/T 05' Z-71 Silverado 16' Z-71 Silverado Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904 |
#17 |
What did you do for the motor mounts/perches on the frame? Frame is looking good!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#18 |
I used perches and mounts from ece there gen 3 mounts come complete with all hardware etc. Mounts have about an inch of movement forward or rearward. Using there trans crossmember as well. Hope that helps.
#19 |
Got cab back on and checked clearance. Fit like a glove now time to mock up brake booster and ac system.
#20 |
I'll be watchin'
This looks like an awesome build!!!
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#21 | |
![]() Following, good looking build. |
#22 |
Thanks everyone for the compliments. I got alot done sinow last post. I'll have to take some more pictures.
#23 |
Looks great so far! Can't wait to see more. I'll be following this one. I'm also dropping in a LQ4.
1971 C-10 SB 2WD - Project Money Pit Project Build: http://67-72chevytrucks.com/vboard/s...d.php?t=606875 |
#24 |
Thanks what year Lq4 are you doing and where are you mounting the ecm?
#25 |
Got interior taken out this weekend and was happy with floor and cab condition. Also finished up modification to my Ls wiring harness. Also got steam port tapped into the waterpump.
