#26 | |
Re: 1972 Blazer CST Frame off Project in NC
Keep all your original trim, especially the windshield trim if you have it. Board member deadheadNm gave me this advice and I'm thankful he did. I have over 2K photos and I'm still second guessing myself where things go. ![]() Keep up the progress!
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
#27 |
I'm trying....
![]() Join Date: Oct 2013
On board. Go Dawgs.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#28 |
#29 |
And now for some pics post sand blasting......
Looks like the PO, seamed the bedside panel at the wheel well. The blaster told me he took about 200 pounds of bondo off! I know he was exaggerating, but there was LOTS on there. I despise shoddy workmanship. Glad to now know what I have, and don't have. I see body panel purchases in my future..... |
#30 |
Ok, so the fun keeps coming! I went by yesterday and picked up my blazer from the sand blaster and took it over to my body guys shop - - ALOT more rot than I had hoped for, but hey, it comes with the territory.
Looks like I will be buying 2 new doors, 2 wheel wells, 2 bedside/quarters and an entire new floor. I know I can salvage some of whats there, but labor will cost more than replacement parts. There is plenty of salvageable rot that we can spend repair labor on. Here are the pics: |
#31 |
More pics - - look at this one horrible weld! It looks like they tried to fill in a dent with a weld?!?!?
#32 |
![]() Join Date: Jun 2002
Good clean place to start. The first blazer I bought (eBay) I almost cried when I finally realized how bad it was, MUCH worse than yours.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
#33 |
Thanks Roger - I appreciate the reassurances. My body guy said he'd seen way worse too - just surprised me that there is not ONE PIECE of OEM steel that doesn't have rot somewhere.....
#34 |
Nice project, good to see another local K5 guy!
#35 | |
PITbut
As for the ORD custom leafs. I just ordered a set. I will post pics when i do the install. Also, as for your front crossmember, i used the 73-74 crossmember from ORD and just made some adjustments. Nice little piece. How much did the sand blasting cost you?
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
#36 |
#37 |
Thanks for the encouragement!
Sandblasting was $800 for the tub, tailgate and hood. I was originally expecting $600, but there were PILES of bondo on the rear quarters and the hood was media blasted to prevent heat warping, so that added time which added cost. The same blaster has done my wheels and frame, and will do my axles next week - and the prices have gotten better as I do more. |
#38 |
So, here's an update post:
I found a classic truck parts supply business 40 miles from my house - a curse and a blessing! Great guy, good parts - just too easy to go there and buy stuff. My last trip there was a new bedfloor, both rear quarters, wheel wells and a fuel tank. Yes, that's right, I am trashing the entire rear section of the blazer and starting over. After blasting, it was obvious that the rear quarters were shot, and the bedfloor was like swiss cheese - so even though the bedfloor is a pricey part, it will be cheaper than the labor I was going to have to put into it. Pics below, and a pic of the freshly blasted frame as we were prepping it for paint. I opted for paint over powdercoat as I know I will scratch and ding it here and there and wanted the ability to repair it as I did. Also, in the last pic is the crossmember that separates the cab floorpan from the rear bedfloor. Its teh piece that comes up 90 degrees from the floor and forms the 'riser' that the bedfloor folds over and welds to. Does anyone know the name of that part or better, have any leads on a replacement? I am screwed without it! |
#39 |
I think I saw the bed to cab support from wes at ?, cant remember his company name. Some one on here will know it...classic?
#40 |
So thats the name? Bed to Cab support?
Thanks! |
#41 |
Also, here are a few more progress pics!
ORD came through with the leaf springs. I also tackled the Transfer Case......I got it apart, now we will see if I can get it back together. Also have the axles stripped down and getting them ready to prime, paint and rebuild. Same plan with the tranny.....I found a guy who has been in business 43 years and knows a TH350 inside and out - - used to build tractor pull trucks. |
#42 |
Great progress! Which local classic parts suppliers are you using?
Those springs look like they will be far superior than factory (many thin leaves rather than few thick leaves). Would you mind sharing the specs? price? |
#43 |
I miss this truck.
Interesting build.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#44 | |
The springs are 2.5" lift. I only want to run 33s and was really looking for more ride quality than height, and the guys at ORD were great at listening to me and helping devise the right solution. Just over $1400. |
#45 |
![]() Join Date: Jun 2014
Wes at Classic Heartbeat in Olympia WA
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
#46 |
You guys are awesome! Thanks
#47 |
I got my springs through ORD also with a similar lift amount. I will say when it came time to install the Rears there was a bit of pre-load required similar to a coil pack. Took a couple of red-neck tricks to get them in. In the end they nailed the stance but I don't have mine back together yet to see what the ride is like.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#48 |
#49 |
Lol. Can you use that CRAFT to get that part off national back order? Supplier says 30 to 60 days........ You need patience to restore a rare classic. I'm dead in the water until it shows up.
#50 | |
just remember to make it longer, as it extends into the 'B' post Or you could degrease and paint parts for the next 30 to 60 days PATIENCE? I've been at it for 15 years lol
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-14-2016 at 07:40 PM. |
