Old 01-28-2013, 10:24 PM   #26
Blue97
Blue97's Avatar
Re: remove power assist steering on 97 Silverado?
The steering sensor is responsible for some of the front end wander but it also comes from worn idler arms and pitman arms, etc. If you do replace the idler arm go with a hd unit from Moog. Also if it's not had an alignment after the lift now is the time. A toe out condition will make her wander as will tire inflation, tire wear, etc.
I suggest you unplug the sensor at the steering pump and drive it to eliminate it as a possible cause.
great advice.
I replaced everything with MOOG aswell.
when i was running 35's i had to adjust tire pressure and the good ol chalk method worked for me...
I disconnected at the pump and have been so happy since!
Blue97 is offline   Reply With Quote
Old 01-29-2013, 07:22 PM   #27
steelhorse
steelhorse's Avatar
If it is the twitching that is bothering you then replace the steering sensor at the bottom of the steering column{in the cab}and that should fix it.
steelhorse is offline   Reply With Quote
Old 01-30-2013, 08:18 PM   #28
Blue97
Blue97's Avatar
I replaced mine awhile back and it did nothing for it, i think my problem was more at the pump.
Old 07-13-2016, 09:38 AM   #29
Coursey
Coursey's Avatar
good info.
Coursey is offline   Reply With Quote
Old 03-27-2017, 12:23 PM   #30
Coursey
Coursey's Avatar
Has anyone tried to use GM #19168825
I have unplugged my EVO wire, which helped the "bump steer" feel. But it also caused it to be over assisted. Will the GM #19168825 help with the over assisted issue?
Old 12-02-2017, 11:38 AM   #31
bcbbab1
Did anyone get this figured out?
My alignment is good. All new front end parts. Tires aired. I am having the same issue; at highway speeds it seems to have too much power assist. Wheel turns too easy. I unplugged the wheel sensor on the column under the dash and it didn't make a difference. Lost here. Might try welding a couple of brackets so I can mount 2 stabilizers? Need help!
bcbbab1 is offline   Reply With Quote
Thread Tools
Display Modes
