01-14-2019, 03:55 PM | #26 | |
Re: Intermittent power loss (need help troubleshooting please)
The first is manual actuation (short video): https://youtu.be/eWjX0byOYRQ The second is automatic actuation as the vehicle warms up from 40 degrees F (8 and a half minutes long - skip to the end if you want - turn your sound down - loud): https://youtu.be/94MVneCeIDE Everything appears to be in proper working order to me, but I don't really know what I'm looking at beyond the whole air - fuel - spark triangle here. Last edited by trevarthan; 01-14-2019 at 04:26 PM. |
01-14-2019, 04:22 PM | #27 | |||
The vacuum line on the driver side of the "T" Looks like it is connected to a port in the intake manifold: Quote:
The other goes to that port on the carb below the b-nut: Both go to a sensor of some kind on the air cleaner assembly. top of air cleaner, open and removed: bottom of the air cleaner: That sensor is labeled AC (auto choke?) and looks like it has a port for an electrical connector (inside the air cleaner), but it's never had anything plugged in there for as long as I've owned it. No clue what that is. Let me know if you know. I'm curious. Quote:
I've tested the vacuum advance on the distributor with a rented hand held vacuum pump. Seems to be working (saw the lever move), but I don't know if it's within spec or not because I don't know the specs or where to find them. EDIT: I just noticed you asked about that sloped port on the carb. It does appear to be drilled to me, according to this photo with the cleaner removed: I took a video of the auto choke opening for the previous poster. At the end of the video I pan around the carb a bit for you. This link should take you right to that point in the video (turn your sound down - loud): https://youtu.be/94MVneCeIDE?t=473 Last edited by trevarthan; 01-14-2019 at 04:37 PM. |
01-15-2019, 12:13 AM | #28 |
I dont mean to throw you a curve ball here, but I had a similar situation in my last truck. It would stumble randomly. In the beginning it appeared to be doing it under load. I replaced fuel filter and pump to no avail. I then rebuilt the carb. Still happened sporadically. IIRC I tried a known good coil. Still no luck. Eventually I traced the problem to a crappy splice in the main power wire coming from the battery, via the small distribution block on the passenger fender, to the fuse box. I soldered and shrink wrapped the faulty splice and was back in business.
Years later I had a similar problem in my Suburban. I traced it back to a loose bulkhead on the backside of the fusebox.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
01-15-2019, 10:17 AM | #29 | |
How did you determine it was a bad splice? Jiggle the cables? I've been doing that and I haven't noticed any odd behavior. I may still not be jiggling the right one though. |
01-15-2019, 12:12 PM | #30 |
The Older Generation
Have you replaced the gas cap lately by any chance? If it runs for a while before becoming sluggish it could be creating a vacuum in the tank. I know someone earlier mentioned taking the cap off to see what happens but not sure if that was tried. The sock filter on the end of the pickup tube in the tank would be at the top of my list of things to check, as would be a plugged fuel line from tank to pump. Here are pictures of a plugged sock filter and pieces of a filter that were plugging up a fuel line. LockDoc
01-15-2019, 12:43 PM | #31 |
no. the cap may be original for all I know.
It has not been tried yet. Removing the cap after a stall doesn't seem to help with the hard restart issue and I certainly don't feel or hear any vacuum when removing the cap. I'd be shocked if the cap on it now is air or gas tight. |
01-15-2019, 12:58 PM | #32 |
The valve inside the air cleaner operates with heat, to open the snorkel door for cooler air to enter, after the engine warms up.
The vacuum port for the Thermostatic Air Cleaner (Thermac) should be capped or plugged with the air cleaner off and the engine running. You are providing a vacuum leak the upsets idle mixture and idle speed. You have three hoses on the charcoal canister, visible in your video. One hose goes out of sight under the battery. Does the end of that hose have the nipple that is missing from the carb? The choke rod coming out of the Bi-metal Choke Stove on the exhaust manifold is working in your video. The choke has two functions. When you step on the throttle of a cold engine the high-speed idle is set along with the choke. I.E. together. Heat turns off the choke (opens the choke valve) , independent of the high-speed idle. By once again stepping on the throttle, the high-speed idle mechanism is released. The rod on the back side of the carb is connected to a high-speed idle cam. Your high-speed idle mechanism is obviously not working properly. Some carbs have a idle speed screw and a separate high-speed idle screw. Yours may not. Fix the missing large nipple on the carb, cap the lower vacuum port, warm the engine up and adjust the idle speed down to a reasonable rpm. At that point see what you need to do to get a correct high-speed idle. That missing nipple would certainly have allowed dirt and water to get into the float bowl so you may need to rebuild the carb. I am not certain if or how much that open hose would have upset the vacuum in the charcoal canister.
'67 GMC 2500, 292, 4spd, AC |
01-18-2019, 07:41 PM | #33 |
Replaced the ignition switch. No change. Still happening. My timing light arrived this week. Plan to have a look at that this weekend and have a look at the vacuum lines/ports as suggested. May replace the fuel pump too.
01-19-2019, 01:02 AM | #34 |
Msgt USAF Ret
Back in the early days when catalytic converters were new they would sometimes plug partially and performance would drastically decrease. I know you don't have a converter, but have you checked your muffler and exhaust system for a plug? If the truck has sat for a while the critters might have built a nest in there and that might be your issue.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-19-2019, 12:03 PM | #35 | |
01-19-2019, 12:05 PM | #36 | |
01-19-2019, 12:08 PM | #37 | |
01-19-2019, 01:02 PM | #38 |
No. That hose goes to the frame rail and converts to a metal tube. I assume that is the vent line for the gas tank.
01-19-2019, 02:38 PM | #39 |
No, You just have to remove the sending unit from the tank. You should be able to get to it by sliding the seat forward as far as it will go, disconnect the fuel line fitting, remove the sender lock ring (spray it with some penetrating oil before trying to remove it) and pull the sending unit out. If you disconnect the inlet line from the fuel pump you can then blow through the line from inside the cab with an air hose to clear the line of any internal junk. Make sure there are no filters between the tank and fuel pump. LockDoc
01-19-2019, 02:41 PM | #40 | |
I also bought a fuel pump and a carb rebuild kit and cleaning kit from autozone today. But first I'm going to check the timing and pull the spark plugs and photograph/replace-as-necessary. Stay tuned. This would suck a lot less if it wasn't pouring rain today. All week it's dry, but I work. Of course it rains on the weekend. Sigh. |
01-19-2019, 03:45 PM | #41 |
I'm excited because I finally found something that is definitely broken! Ha.
The heat riser valve spring is definitely broken: Here's a quick video of me manually actuating it: https://youtu.be/IL0KQFsW2K0 I'm googling, but I'm having a hard time figuring out how important this is. What affect will a broken spring have on engine operation, and what do I have to do to fix it? Thanks! |
01-19-2019, 04:38 PM | #42 |
Granted, I haven't set the idle yet, but a quick check with the timing light and the vacuum advance disabled indicates 14 degrees before TDC.
The plate under the hood says 4 degrees BTDC, but I see a lot of people on the forum here saying 12 to 14 is fine. |
01-19-2019, 06:29 PM | #43 | |
The exhaust should open it up when the engine is running. The spring closes it. I would try an auto parts store for the spring. Not sure if you can replace it without taking it apart or not.... maybe. LockDoc
01-19-2019, 09:10 PM | #44 |
Spark plugs removed.
I don't really know what I'm looking for, but I notice:
from left to right: 1,2,3,4,5,6 another view, bottom to top: 1,2,3,4,5,6 #1 plug immediately after removal: #2 plug immediately after removal: #6 plug immediately after removal (definitely in the worst shape - blackened, makes sense given the dieseling issue): |
01-19-2019, 09:28 PM | #45 |
We're removing the fuel pump now.
After sitting for 20 minutes in the driveway, the line from the fuel pump to the tank was dry when disconnected. I was expecting fuel in this line. Is this normal? The metal b-nut line to the carb was under a bit of pressure and full of fuel, as expected. |
01-19-2019, 10:29 PM | #46 |
Fuel pump replaced. Still stalling. The stalls are more frequent now. We have to keep our foot on the gas a little to keep it running now. When it stalls, it's real hard to restart.
Feel like we're making it worse with all of these part replacements. :p |
01-20-2019, 11:53 AM | #47 | ||
Still sounds like the carb needs a good cleaning and rebuild.
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 01-20-2019 at 12:04 PM. |
01-20-2019, 01:57 PM | #48 |
Fuel pressure gauge plumbed before the carb would tell you a lot. Too little or too much pressure will cause you problems. It will tell you if anything at all is wrong especially if you can see it from in the cab while your driving. Well worth the money if you can get one. Otherwise your guessing with fuel.
01-20-2019, 02:30 PM | #49 |
This has been ongoing for a while now hasn’t it? Seems like you have been over many many possibilities, like trying to find it using pot luck almost. Sorry I’m not meaning to be rude I’d love to help you fix this. Not followed everything you have done but If it was my problem I’d go back to basics which will quickly tell you where your problem is as there is not much to the basic operation of these engines. So here goes back to basics
-Compression test and leak down test ( check your engine is actually capable of running correctly) -Fuel pressure, no guessing you need to know what it is -Ignition. The only wiring you need is a +12 wire directly from batt to distributor and a ground wire from distributor to battery. These can be temporary wired in for purposes of proving your wiring system After these basic steps you will either find your problem or know exactly where your problem lies. Go back to basics until you find your problem then you can get technical when you know where to get technical. Hope this helps you get methodical in your faultfinding. Best of luck, Dave |
01-20-2019, 03:35 PM | #50 |
I would love to be able to test the fuel pressure. Tell me what to buy and how to install it.
My understanding is that it's kind of a pain in the ass to test pressure with these mechanical pumps because they pulse and your needle will just jump constantly. I disconnected the bnut from the carb this morning and had my son crank it. Squirted fuel all the way onto the transmission bell in the back of the engine bay. My non-scientific feeling is that the fuel pressure is fine. |
Thread Tools | |
Display Modes | |
