#76 | |
![]() Join Date: Mar 2015
Re: 1972 K10 Disabled Veteran First Build
#77 |
Cool build thread. I was surfing the site and stumbled across your build. this should be put in the 4X4 build section. I will be watching.
#78 |
Thanks for saying hi. This is my first time using the using the site and didn't know for sure where to start the thread. Should I contact someone about having it moved? Also I would like to become a premium member like yourself, is there someone I should contact? I believe it's $25?
#79 |
I made the same mistake as you did when I signed up and posted in the wrong section for my build. One of the modrators will move it for you like they did my build thread. At the top of the home page you can become a premium member by clicking subscribe button
#80 |
#81 |
![]() Join Date: Jun 2012
It opens the passenger vent. Opens and closes with vacuum
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#82 |
#83 |
I'd have to go out and follow the lines, not sure off the top of my head
#84 |
[QUOTE=tommys72;7173759]I'd have to go out and follow the lines, not sure off the top of my head[/QUOTE
Ok just curious. Really isn't going to matter until I start putting it back together. There was nothing connected to it when I got the truck. I assume it must be set up so the driver can open and close both vents? Semper Fi. |
#85 | |
[quote=0311Chevy8152;7173762]
Semper Fi brother
#86 | |
On non-A/C trucks there is a matching direct manual operation passenger inlet air vent. However on A/C trucks like yours, was, this became the air recirculation door. It is vacuum motor operated to allow interior air to be sucked into the A/C inlet plenum when the outside/fresh air door (also vacuum motor operated) is closed. Might be best to review the factory service manual on the A/C system if the picture does not clear this up for you. * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID Blazer SPID Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#87 | |
#88 |
#89 |
You've even got the original gun rack in there, that's awesome!
#90 |
#91 |
#92 |
just found this, nice build...
22 yr army vet here, still in...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#93 |
Advice please: I removed the lights and tailgate from the bed preparing to start disassembling the bed. I stopped before I even started when I saw welds between the bed and side panels. Originally I thought they just bolted together. The bed definitely needs work, the floor is dented in several areas, the wheel wells have lots of dents, the side panels on one side has a bunch of bondo you can see at the bottom of the panel, both sides have old fuel doors which I do not want anymore, and there is probably more I am not seeing. So, should I grind welds take apart bed (if that is even possible), or buy a bed (how much will that cost)? Thank you in advance for taking the time to reply. I greatly appreciate it.
#94 |
Their are about 4 to 6 welds that support the bed floor and side you can grind the weld and use a chisel to separate them. you will have to check alignment and weld them back together when you have completed the body work.
#95 |
Is it difficult to realign after taking it apart? I assume it would be more thorough for me to take everything apart. Is that your recommendation?
#96 |
Sky from Sky's Hot Rods finish up the sheet metal work on my truck. I did grind the weld and take the bed apart as I went from 8' bed to 6' bed and use what I could from the 8' to save money and buying part. the bed side will bolt together and you align the tailgate gaps then weld it back up. its not that much work. knocking out the dents is where all the work is. I did buy a new metal bed bottom salvaged the rest from 2 beds.
#97 |
My experiance is one approx 1" weld on each side of the rear steak pocket, the rest is all bolts and nuts, there are some almost hidden bolts under the rear corners, ya really got to look for them.. the bedsides are awkward, 2 people or a way to support them like a cherry picker are a good idea
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#98 |
Might not seem like progress to some but it's progress to me. I removed one wheel well and getting ready to start the second. The old bolts are not fun to work with. I wish they would break off like some but most just spin. My new hip is getting a good workout going up and down a ladder to get into the back of the truck. I can't wait to see just a frame.
#99 |
![]() Join Date: Oct 2013
Oh man have to love rusty bolts !Have an awesome week end and thank you for your service to our Country.
#100 |
Actually when your by yourself doing body work can be a pita, especially when the carriage bolts want to turn when your trying to remove them. One trick for rusty bolts i have learned thru the years is to just tighten them until they break off cause you don't want to re use rusty bolts anyway, bolt kits are pretty cheap, the only possible drawback besides a bloody knuckle may be that if the body flanges are really rusted they may give a little, but if they are that bad they need repair anyway.
Thread Tools | |
Display Modes | |
