Old 06-21-2002, 09:40 PM   #1
johnymac
Question 3.5 /6 drop need front tires that fit??
I had a 3/5 drop on my truck, bought some 275x60x15 tires last year, they fit great.
This year put in 2.5 " drop spindles and 1" drop coil springs in the front of the truck. I thought the front tires would fit, not. Seems the 3" drop springs I had on last year, were not a true 3" drop. The drop spindles also put my tires out to the outside fender now.
At first the truck sat fine, but the last couple days seems to be settling, I have about an 1.5 clearance before hitting the fender/ inner fender well, I am bummed.
Just curious what size front tires should be run on such a drop. Problem I have now, is don't want a smaller diameter tire, can't afford to have this thing drop any more, my lower control arms and collectors from my headers are about 3 inches off the ground now.
Please, any suggestions??
Thank you.
johnymac is offline   Reply With Quote
Old 06-22-2002, 05:12 PM   #2
JHickson6
I Love This Stuff!
JHickson6's Avatar
What brand of 3" drop spindles did you buy??
JHickson6
JHickson6 is offline   Reply With Quote
Old 06-23-2002, 09:48 AM   #3
johnymac
Sorry, I was not careful writing my post. I had 3" drop springs in the front last summer, not 3" drop spindles.
Sorry...
Old 06-23-2002, 01:38 PM   #4
JHickson6
I Love This Stuff!
JHickson6's Avatar
Doh!
what are you sorry for i'm the one that can't read!!!
Doh!
Old 06-23-2002, 06:42 PM   #5
johnymac
Cause it read 3" drop spindles instead of springs, I fixed the post.
Thanks for catching it
Old 06-24-2002, 04:43 PM   #6
Frank_Zeller
Frank_Zeller's Avatar
Running BFG 235/70R15 in front with 7 inch wide rim.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 06-25-2002, 07:14 PM   #7
Chevyc10!
Chevyc10!'s Avatar
I have 255/50's on 8" rim with 4" drop in the front. No rubbing here...
68 SWB
The Surgeon General doesn't say anything about smoking a Ford!!!
Would rather be ran over repeatedly by a Chevy than drive a Ford!!!
Paralyzed from the neck up and confined to a hat!
Kathleen, Georgia USA
Chevyc10! is offline   Reply With Quote
Old 06-26-2002, 07:11 AM   #8
johnymac
Thanks for the replys!
I bought a 1" spacers for the springs. I will use until I need new tires then will try out a 255. My 275 just to dam big!!
Thanks guys!
Old 06-26-2002, 03:17 PM   #9
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Chevyc10, Do you have any close ups of the front tire/fender? I haven't put my front end back together yet and I've got 265/50/15's on 8 inch rims for up front. I want to do a 6/8 drop and I need to know if I'm going to have to modify my inner fender. If it's going to hit my outer fender then I'm going to a narrower tire.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
