01-12-2005, 06:07 PM | #1 |
rear panel template ?
Anyone finished with the template that Diane was sending out ? I could use one.
Bret
71 Custom 20 Deluxe..soon to be SWB 1/2 ton 1 incredible wife 2 great kids |
01-24-2005, 10:39 PM | #2 |
ttt........I will pay !
01-30-2005, 11:36 AM | #3 |
Got L.E.D.s
:tj: These are easy to make yourself. First measure front to back and top to bottom, and cut out a rectangle in that size.(I used 3/4" high density partical board). Then put that on the inside of the wheel well and then use a piece of cardboard cut to the width of the wheel well. and draw the line out and cut. Then radius the edges with a routor. And rap the thing with 1/4" thick foam and then with the material you want.
Sorry I suck at directions.
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
