Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 04-06-2005, 01:14 AM   #51
FirstGen
Just Don't Stop!
FirstGen's Avatar
Basically these are the parts I used:
1968 C20 lower control arms
1990 3/4 ton Light Duty 2X4 must have (1.25" rotors) spindles
1990 1.25" thick 6 lug rotors
1990 calipers off same truck
1990 upper and lower ball joints
1990 outer tie rods
inner tie rods MOOG part #ES2020RL
1990 style tie rod coupler
The only catch is to cut 3/4" off each end of both tie rods on each side of the truck so you can have enough room to align the truck. Well at least I had to since mine is lowered 4" in the front.
The front end I bought off the 1990 truck was 5 lug. All I did was went and bought the 6 lug rotors and bolted them on. If you wanted to stay with the 5 lug, you'd save yourself about $120 bucks.
After everything is done, you will now have 14mm studs on the front. I fixed this by drilling my rear axles and pressing in 14mm studs in the rear also but you wouldn't have to do this... I plan on going to a rear disc setup using a floating rotor design and so this helps that plan also...
Good luck.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline
Old 04-06-2005, 12:12 PM   #52
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
what ball joints did you use?
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline
Old 04-06-2005, 05:21 PM   #53
FirstGen
Just Don't Stop!
FirstGen's Avatar
if you read my last reply it's says 1990 upper and lower ball joints.
TT LSA/6L90e/9"
FirstGen is offline
Old 04-06-2005, 06:32 PM   #54
shifty
Questionable
shifty's Avatar
Thanks for the info, FirstGen. Did you need to modify your brake line or brake line assembly at all? I've noticed some people (normally in the back) welding on new L-brackets to hold the tap between the hard line and the flex line. Did you re-use all existing fittings and lines or buy new ones?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline
Old 04-06-2005, 08:32 PM   #55
FirstGen
Just Don't Stop!
FirstGen's Avatar
I used the rubber lines off the 1990 truck and used the factory mount from the 1990 to secure the line to the frame. Never ran new steel lines until later when I just wanted to, it wasn't nessary to do the swap.
TT LSA/6L90e/9"
FirstGen is offline
Old 11-21-2005, 07:16 PM   #56
JRB
JRB's Avatar
Re: easy disc brake swap
DO you know if the 68 3/4 ton Lower A-Arm is the same as the 69? Thanks in advance for the help.
Bruce
JRB is offline
Old 11-21-2005, 08:22 PM   #57
FirstGen
Just Don't Stop!
FirstGen's Avatar
Bruce
I'm sure it is. Call Ed at Mothertruckers and ask him, he will know for sure...
TT LSA/6L90e/9"
FirstGen is offline
Old 11-22-2005, 07:21 PM   #58
krue
Designated A-hole!
krue's Avatar
Bruce
Ask on the main board for confirmation, but I'm pretty sure they are the same as well.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline
Old 11-26-2005, 08:28 PM   #59
doc70sub
doc70sub's Avatar
I wonder if you can utilize the '88-'98 3" lift spindle while doing this swap....I'd like a little lift on my '70 C-10 Sub!!
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline
Old 12-02-2005, 07:35 PM   #60
GMC69mnypit
!Women...!!!!
GMC69mnypit's Avatar
Did anybody else that did this swap with factory ride height have serious alignment issues like I have??? Not toe, caster / camber...
'69 GMC 1/2T LWB 2WD
'02 Silverado 2500HD 4X4
'79 ElCamino SS
GMC69mnypit is offline
Old 02-06-2006, 04:23 PM   #61
68jimmy
68jimmy's Avatar
GMC69mnypit, did you ever get that alignment issue resolved? If so what was the cure?
thanks.
78 C10 LWB Super Cheyenne
68jimmy is offline
Old 04-24-2006, 08:58 AM   #62
jamon8
jamon8's Avatar
I got one question!
Why do you have to have the 70 3/4 ton lower control arms to make the 87 and up spindals work.
I have a 69 c10 and a 89 1500 parts truck that I am taking the trans out of.
This sounds like the way to go and I am glad I got involved in this forum.
Do I HAVE TO GET the 3/4 lower control arms?
jamon8 is offline
Old 04-24-2006, 10:27 PM   #63
doc70sub
doc70sub's Avatar
Yup, for the larger ball joint in the 3/4-ton a-arm to match the larger later model lower ball joint.
doc70sub is offline
Old 04-25-2006, 07:41 AM   #64
jamon8
jamon8's Avatar
can you put a 3/4 ton ball joint in a 1/2 ton lower control arm.
I am really enjoying these modifications. It seems that the sky is the limit with these old trucks
jamon8 is offline
Old 04-28-2006, 05:35 AM   #65
HarrisonTX
Hello
What a great post
I have a '69 3/4 custom camper, would i just need to get parts from a newer 3/4ton? Thanks!
'69 custom/camper
'74 260z 302 chevy/tko500 swap in progrss
'79 Malibu 355 all forged 4 speed car.
'86 k5 blazer
'06 Duramax
HarrisonTX is offline
Old 05-17-2006, 04:47 PM   #66
texascowboy593
texascowboy593's Avatar
to keep this alive and kickin'...Anyone know if it'll work on a 67 GMC??? Thx so much in advance!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline
Closed Thread
