Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 04-02-2005, 01:00 AM   #26
powell72
powell72's Avatar
That would be great, no rush though.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline
Old 04-03-2005, 09:24 PM   #27
Boog
laying low
Boog's Avatar
wheels
I am probably going to go with either the truck or vette ralleys on my 69 step. I am wondering if there are other center caps that fit the truck ralleys besides the original caps? It would have to bolt on as the original ones or snap over the lugs like the later model ones I suppose.
What are the center cap options for the vette ralley besides the big derby?
It's time to make a decision.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 04-04-2005, 12:23 AM   #28
powell72
powell72's Avatar
You can go with either a pancake cap or a disk brake cap which isn't as big as a derby.
Chris
powell72 is offline
Old 04-04-2005, 09:50 PM   #29
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
These older threads have some good wheel/tire posts
http://67-72chevytrucks.com/vboard/s...=125001&page=1
http://67-72chevytrucks.com/vboard/s....php3?t=133948
Dual quad is offline
Old 04-10-2005, 10:43 AM   #30
billogna
billogna's Avatar
Front: wheels- Cragar SS, 17x8, 4.5" bs
tires- Nitto, 255/50 (outer tire rubs over big bumps, recommend 245)
drop- 3" drop spindles + cut springs = about 5"
Rear: wheels- Cragar SS, 17x9, 4.5" bs
tires- Nitto, 275/50
drop- 5" drop coils + .75" blocks = 5.75"
Exhaust rerouted to outside of frame since pics, going .5" lower this summer.
billogna is offline
Old 04-11-2005, 12:02 AM   #31
BabyBlue
The Peacemaker
BabyBlue's Avatar
My dads old truck
Heres my Fathers old 1972 Cheyenne Super, he sold it back in 99'
If I remember correctly the truck had a 6/8 drop spindles & coil up front and coil for the rear. All I can really remember is that it had about 1.5-2" of clearance under the A-arms
It had Polished Torque Thrust D's
Front - 15x8 w/standard backspacing (I believe its 3 3/4") with 265/50's
Rear - 15x10 w/standard backspacing (I believe its 3 3/4") with 295/50's
Just in case anyone wants anymore pics find them here
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline
Old 04-22-2005, 12:29 AM   #32
Autometer
Autometer's Avatar
Originally Posted by powell72
4/6 drop, 15x8 Rallys with 4'' of backspace, 245/60/15 front, 275/60/15 rear tires.
Mine sits just like yours with the same wheels but have 295/50-15
'05 Silverado
'02 Avalanche
'85 C10
'71 C10
'51 3100
Autometer is offline
Old 04-27-2005, 03:24 PM   #33
twitch4187
Need yalls help here I want to put Eagle alloy Series 054 wheels front 15x8 with 3.75 bs and rear 15x10 with 3.69 bs on a 68 stepside. The tires I want are Hoosier Quick Time DOT p245/60d-15 up front and p275/50d-15 in the rear with a 2 in coil drop in the front and 3 in coil drop in the rear. Will the tires rub the fenders?
twitch4187 is offline
Old 05-19-2005, 10:24 PM   #34
DevinM
DevinM's Avatar
Here are some links to other threads in this board. (since the search function is disabled).
http://67-72chevytrucks.com/vboard/s...ad.php?t=77833
http://67-72chevytrucks.com/vboard/s...ad.php?t=58189
http://67-72chevytrucks.com/vboard/s...ad.php?t=75080
http://67-72chevytrucks.com/vboard/s...d.php?t=110962
http://67-72chevytrucks.com/vboard/s...ad.php?t=29980
'71 Chevy C-10 - Current
'62 Imapla SS - Traded for my current
'73 Nova Hatch - traded for ATC-350X
'73 Chevelle Deluxe - First car (R.I.P)
DEERFIELD, MA
DevinM is offline
Old 05-20-2005, 05:36 PM   #35
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
These are 15 X 8", eight lug. Tires are 31 X 10.50 biased ply Deltas
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline
Old 05-22-2005, 07:08 PM   #36
DevinM
DevinM's Avatar
WHEELS: Boyd Coddington Timless 5's (Cast Series)
I believe they are no longer in production. Now the
Timeless 5's are only available in the *****in' Series (Billet).
Front's : 20 X 8 w/ 4.5" backspacing
Rear's : 20 X 9.5 w/ 5" backspacing
TIRES: Bought mixed set to save a little $$
Front's : Toyo Proxes ST 255-40-20
Rear's : Hankook Ventus ST 275-40-20
DROP : ECE 4/6 drop kit.
To see Before, After and After w/ Tires : CLICK ME
DEERFIELD, MA
DevinM is offline
Old 05-29-2005, 05:56 PM   #37
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
Here is mine...
Front 15x7 w/3.75 bs 255/60/15 YOKAHOMA AVID S/T
Front dropped w/2.5 spindals
Rear 15x8 w/ 4.0 bs 275/60/15 YOKAHOMA AVID S/T
Rear dropped w/4" coils and adj. track bar
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline
Old 05-30-2005, 07:09 PM   #38
speedracer
Blank
speedracer's Avatar
i'm running a 4-6 drop with a lwb 69 with 5 lug conversion. I have american racing torque thrust II's 17x8 up front and 18x10 out back 245 45 17 front 275 40 18 rear tires came straight off a 2003 vette pirelli p zeros. 4" backspacing in front 5" in rear looks great I'll have to get some pics on here
speedracer is offline
Old 06-09-2005, 04:51 PM   #39
farside847
farside847's Avatar
Well, since my set up has changed, I thought I would post my truck here again. Look at my last post on this thread to see what it was like before... Now it has 15x8 ralleys and BFG Radial TA 255/70/15 on all four. Still set at stock height. My wife says its "sexy"
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline
Old 06-09-2005, 06:01 PM   #40
smbrouss70
smbrouss70's Avatar
Waiting on your pics... I want to see what it looks like with 17's and 18's with a 4/6 drop.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline
Old 06-29-2005, 01:34 AM   #41
tomatocity
tomatocity's Avatar
Originally Posted by Fmspeed
72' w/ 68 clip, stock rear LEAF, 2" front "blowtorch" drop, 20" 275/45/20" all the way around. I'm thinking needs bout 2" down in the back, now just gotta figure out how many bricks to load up.
Looks good.
Save the bricks and use extended shackles (1.5"-2.0"). Inexpensive and you will get a new bushing in the deal. Not only will it lower the rear but it should also ride better with teh new bushings.
I am glad to see your pics since I am trying to decide how to lower my leaf truck approximately 6". Drop leafs; drop mono leaf, standard curl; drop mono leaf, reverse curl; extended shackles; flip kit; c-notch, c-notch kit; rear shock relocators;...
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline
Old 06-29-2005, 08:57 PM   #42
72MARIO
72MARIO's Avatar
How about dearched 3" or 4" and a 2" shackle ? Thats what I have done. Should be good While the springs are in the shop get new bushings installed.
Note.
2" drop shackles will not work with a wood floor. Thats why they make the 1.5" shackle.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline
Old 07-01-2005, 07:16 PM   #43
Rokcrln
Rokcrln's Avatar
Right now mine has the old tires on. My others are in storage while I get the shop set up ( just moved). But what goes on the truck are 17" ralleys with 335/35/17's in the rear with a 7 1/2-8" bs on an 11" rim. Up front they are 245/40/17's with a 4 1/2"bs on 9" rims if I remember right. The truck is bagged, body dropped 2", 3" drop spindles in the front and about 2" notch and 4" Z frame in the rear. The rockers sit about 5/8" off the floor and tires stuff up fully with about 1/4" femder to side wall gap.
Rokcrln is offline
Old 07-01-2005, 09:07 PM   #44
72MARIO
72MARIO's Avatar
That Looks Killer..
2005 TAHOE DD
72MARIO is offline
Old 07-09-2005, 06:09 PM   #45
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
16x8 Eagles with 275/65/16
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline
Old 07-09-2005, 09:45 PM   #46
tomatocity
tomatocity's Avatar
Bill are those Alcoa rims? I really like them the best of the larger rims. Very nice.
Old 07-16-2005, 09:12 PM   #47
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
anyone done a 4/6 or 5/7 drop with 20's up front and 22's rear or 18's up front and 20's in the rear? Like to see that with info.
-Ron-
OldSkool71 is offline
Old 07-21-2005, 01:55 PM   #48
Swbman
Is a 275/60 the widest tire that can be put on a 15x8 rally?
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline
Old 07-22-2005, 11:39 PM   #49
72MARIO
72MARIO's Avatar
It's the best looking tire IMO for a 8" Rally. Go with a 275 60 and you will be happy,
2005 TAHOE DD
72MARIO is offline
Old 07-26-2005, 04:50 PM   #50
Swbman
Is anyone running 50 series tires on rallys, if so what size are you using for front and back? Would a 295/50/15 look good and work on a 15x9 wheel for the rear?
Swbman is offline
