Old 07-11-2005, 01:18 AM   #1
Green Machine
Green Machine's Avatar
New cowl to hood seal problems - help
Tryed to install a new cowl to hood seal on my '68 today and it seems the the edge hits under the hood on the top side not rear most edge. The new seal is shaped like an " L " and I'm thinking it should be shaped more like an " < ". Don't have an original to compare to. It holds the hood too high when on so I removed it for now. Any ideas ? Thanks for any input.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-11-2005, 05:50 AM   #2
JimKshortstep4x4
Talking
You are right about the shape of the seal, it should not be like an "L". The only suggestion is to get a different brand seal. The last seals that I got from Christians Truck parts worked real well and they are the right shape.
I am sure other vendors have good ones also.
Jim
Old 07-11-2005, 04:04 PM   #3
KEH
Better late than never
KEH's Avatar
I installed a new cowl seal (bought from Tim) over the weekend and have the same problem. If it doesn't relax to the correct position after a while then I will reinstall the old seal.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 07-11-2005, 08:39 PM   #4
Green Machine
Does anyone have a picture or what it should look like and/or a couple of measurments ? Thanks
Old 07-12-2005, 09:56 PM   #5
Harold Shepard
If it is hold your hood up you might need to look a little further- weak hood springs/ hinges will really show up with a new seal. Try looking at the hood adjustment first and then go from there.
Harold Shepard is offline   Reply With Quote
