12-01-2005, 05:44 PM | #1 |
Alright Alright Alright
header collector sealing problem.
my header collector surfaces seem to be warped. i have aluminum gaskets in there now and no matter how much i tighten them it still leaks. i was thinking of using 2 white paper style gaskets. should i do it? if i do should i use red silicone? should i just get the damn things welded instead (im tempted)?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
12-01-2005, 05:58 PM | #2 |
KEEP ON TRUCKIN'
Re: header collector sealing problem.
Paper gaskets will blow out in no time. I have the same problem. Very tempted to weld them together. I bought a new set of headers for my big block truck that has the ball and flange type collectors. Great design, uses no gaskets and does not leak. I'm thinking of getting a set for the small block truck.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
12-01-2005, 07:42 PM | #3 |
I have used 2 gaskets before and yes it did work for me but they will eventually leak again.I belive the ball/flange setup is the way to go but I can't afford a new set of header's.The problem is everyone tightens the hell out of them to keep from leaking which warps the flange.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
12-01-2005, 08:17 PM | #4 |
its all about the +6 inches
are you running thin alluminum ones, or the 1/4 inch thick dead soft alluminum ones?
Try the latter if you haven't, I have yet to see a header they wouldn't seal. (within reason) |
12-01-2005, 09:07 PM | #5 |
67-72 Addict!
My buddy swears by the foil type donut gaskets. I recently doubled up the dead soft aluminum ones plus used the copper silicone.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
12-01-2005, 10:05 PM | #6 |
yea im using the thin ones but they arent as thin as a a mr. gasket copper gasket. i really want to weld them but thats pretty permenant. if i use 2 gaskets, should i put selant between the gaskets?
12-01-2005, 11:31 PM | #7 |
If your gonna weld, why not use one of these ball flange kits? They're made by Flowmaster. One end welds to the header collector and the other welds to the exhaust pipe.
12-02-2005, 12:08 AM | #8 |
get a set of hooker collectors with the welded flange they are thicker flanges and will straighten out the warped header flanges.then just resuse your aluminum gaskets
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-02-2005, 09:07 AM | #9 |
Captain Ed
I cut the flanges off mine and expanded the pipe to slip over the collector. I happen to have a 3" exhaust so it worked for me, but if you are going from a 3" collector to say, a 2.5" pipe, you can use the slip over adaptors. I also use the band styly stainless exhaust clamps. No leaky here anymore.
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L |
12-02-2005, 05:10 PM | #10 |
what is the website for those ball flanges? the only thing is is that i would need them from 3 in o 2.25.
12-02-2005, 08:29 PM | #11 |
" no matter how tight I tighten them, they won't seal"
That's the problem. They don't need to be that tight. Here is the cheapest solution, and it works flawlessly everytime, for years to come. Go to the parts store, and buy some good collector gaskets, 2 sets (4 gaskets) I prefer the fel pro blue gaskets if you can find them. Then go to your local exhaust shop, and buy an extra set of flanges. All ya gotta do is sandwich the extra flange between the two gaskets, and viola!!! No more leaks. Please submit $1 to my paypal account for this info!!! BTW, here is a pic. |
12-02-2005, 09:44 PM | #12 | |
No No
You suck! I wanted to tell them about that trick. Yep as cst70 said this trick works! Ive done it a few times with warped flanges and it sealed them up with no problems. This also tends to increase collector gasket life quite a bit since the pipes arent constantly rubbing against both sides of the gasket cutting it from both ends.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
12-03-2005, 03:20 PM | #13 |
wow that looks awsome. i think i will try that. thanks for the tip guys.
12-03-2005, 05:13 PM | #14 |
~Rest In Peace~
read the rules. you may only sell or advertise things for sale if you are a contributor
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex Last edited by cableguy0; 12-04-2005 at 02:38 AM. |
12-03-2005, 06:49 PM | #15 |
Well, if cst70rocket's idea doesn't work, and it probably will, you can get the ball mount flanges from www.summitracing.com. They make them for all size pipes.
cst70rocket, GREAT tip. I'm gonna try it myself.
12-03-2005, 09:20 PM | #16 |
Right turn Clyde
I need them in a 2.5 and 2.5 I only see 3.0 and 2.5 for a set. Anyone make those?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
12-03-2005, 09:49 PM | #17 |
i tried the copper ones. they had the same result as the aluminum ones
12-03-2005, 10:46 PM | #18 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-04-2005, 02:28 AM | #19 |
I've found that with the Hooker's that have the collector flange welded, they never leak.
12-04-2005, 03:18 AM | #20 | |
Son Of Gravel Man
I gotta try that gasket trick. My passenger side leaks.
But will probably stay that way till March when it warms up
Daily driven 70 C10 longbed Its a work in progress Quote:
12-04-2005, 12:07 PM | #21 |
i`ve always changed the lip sealing flange over to a hooker type before putting the headers on.it can be done afterwards,but is a pain in the *&%^$#!@?!tack the flange where you want it on the collector end,grind off the lip,run a full bead on the flange,do the same to the reducer,and i`ve always used the hooker header gasket,both head and collector.best if you use new,but i`ve used old stuff too.good luck!!
02-13-2017, 07:07 PM | #22 | |
02-13-2017, 07:11 PM | #23 |
I just posted a reply on similar problem. You tube C Flange Bracket. I have 75 c30 same leaky problem till I used this.
02-13-2017, 07:17 PM | #24 |
Nice. Chk out C Flange Bracket on u tube. Works great.
02-13-2017, 07:19 PM | #25 |
Still likely to leak again. Flatten flange and get C Flange Bracket. U tube it
